1 - 4 of 4 Posts
Banned
This holiday season, make sure your car is at the top of it's game! Enjoy EFI Logics' winter specials on Subaru servicing. Our technicians are among some of the best in New England, one of which is a 7 year Subaru Master Technician.
With winter fast approaching, EFI Logics knows that your car may be in need of some scheduled maintenance. We have put together some winter pricing to help motivate you to get that much needed work that your car may need. Remember, not only does EFI work on performance oriented vehicles, but we are fully licensed in the state of CT to perform general repair and maintenance!
Check out what people are saying about the sales and service we provide at EFI Logics, we are NUMBER 1 across the board on IWSTi.com - EFI Logics Review Thread
Please make sure to follow us on Facebook for deals and specials that aren't always advertised on the web. EFI Logics Facebook Page
Please make sure to call ahead to make an appointment at least 1 week in advance.
Notes:
*We will match any reasonable competitor rates*
*These prices are good until March 31st*
*If you do not see your applications below, please Contact Us*
Tuning:
Our pricing structure has changed for the winter, and you can find all the latest pricing on our Website, but here is a breakdown of pricing now. For those wanting a Stage 1 or Stage 2 tune, save BIG with this new pricing structure!
STi / WRX / EVO- Stage 1/ 2 Map (Exhaust / Intake) $375.00
STi / WRX / EVO - Stage 3 map (Exhaust / Intake / Turbo / Injectors) $425.00
STi / WRX / EVO - Stage 4+ map (Turbo / Injectors / Forged Engine / Methanol) $500.00
Oil Changes:
Oil change (conventional oil, premium filter) - $35
Oil change (synthetic oil, premium filter) - $45
Spark Plug Replacement:
Spark plug replacement (2.0l Turbo - NGK one-step colder) - $150
Spark plug replacement (2.5l Turbo - NGK one-step colder) - $160
Compression Test: - $125
Compression Test with Leakdown: - $175
Brake Pad and Rotor Replacement:
Front brake pad replacement ('04-'10 STi, Hawk HPS Pads) - $205
Front and rear brake pad replacement ('04-'07 STi, Hawk HPS Pads) - $370
Front and rear brake pad and rotor replacement ('04-'07 STi, Hawk HPS Pads, DBA Street Slotted) - $1060
Front and rear brake pad and rotor replacement ('04-'07 STi, Hawk HPS Pads, DBA 4000 Series Slotted) - $1160
Front brake pad replacement ('02-'05 2.0l WRX, Hawk HPS Pads) - $175
Front and rear brake pad replacement ('02-'05 2.0l WRX, Hawk HPS Pads) - $335
Front and rear brake pad and rotor replacement ('02-'05 2.0l WRX, Hawk HPS Pads, DBA Street Slotted) - $920
Front and rear brake pad and rotor replacement ('02-'05 2.0l WRX, Hawk HPS Pads, DBA 4000 Series Slotted) - $1005
Front brake pad replacement ('06-'07 2.5l WRX, Hawk HPS Pads) - $175
Front and rear brake pad replacement ('06-'07 2.5l WRX, Hawk HPS Pads) - $335
Front and rear brake pad and rotor replacement ('06-'07 2.5l WRX, Hawk HPS Pads, DBA Street Slotted) - $940
Front and rear brake pad and rotor replacement ('06-'07 2.5l WRX, Hawk HPS Pads, DBA 4000 Series Slotted) - $1030
Front brake pad replacement ('98-'07 2.5RS/2.5i, Hawk HPS Pads) - $175
Front and rear brake pad replacement ('98-'07 2.5RS/2.5i, Hawk HPS Pads) - $335
Front and rear brake pad and rotor replacement ('98-'07 2.5RS/2.5i, Hawk HPS Pads, DBA Street Slotted) - $920
Front and rear brake pad and rotor replacement ('98-'07 2.5RS/2.5i, Hawk HPS Pads, DBA 4000 Series Slotted) - $1005
Clutch Replacement:
Clutch replacement (STi, Exedy OEM Replacement, flywheel resurface) - $875
Clutch replacement (STi, Exedy Stage 1 HD, flywheel resurface) - $1125
Clutch replacement (STi, ACT Heavy Duty w/Street Disc, flywheel resurface) - $1175
Clutch replacement (2.0l WRX, Exedy OEM Replacement, flywheel resurface) - $695
Clutch replacement (2.0l WRX, Exedy Stage 1 HD, flywheel resurface) - $1025
Clutch replacement (2.0l WRX, ACT Heavy Duty w/Street Disc, flywheel resurface) - $1075
Clutch replacement (2.5l WRX, Exedy OEM Replacement, flywheel resurface) - $850
Clutch replacement (2.5l WRX, Exedy Stage 1, flywheel resurface) - $1075
Clutch replacement (2.5l WRX, ACT Heavy Duty w/Street Disc, flywheel resurface) - $1125
Clutch replacement (2.5l LGT, Exedy OEM Replacement, must bring new/used 2.5l WRX flywheel*) - $775
Clutch replacement (2.5l LGT, Exedy Stage 1, must bring new/used 2.5l WRX flywheel*) - $1000
Clutch replacement (2.5l LGT, ACT Heavy Duty w/Street Disc, must bring new/used 2.5l WRX flywheel*) - $1050
Clutch replacement (Non-turbo Impreza/Legacy/Forester, Exedy OEM Replacement, flywheel resurface) - $625
Clutch replacement (Non-turbo Impreza, Exedy Stage 1, flywheel resurface) - $825
Clutch replacement (Non-turbo Impreza, ACT Heavy Duty w/Street Disc, flywheel resurface) - $875
* We can either buy a new one from Subaru or we can also resurface a used one if need be.
Mount and Balance Tires
17" or smaller wheels (set of four) - $85
18" (set of four) - $100
19" or larger wheels - Please Call
Scheduled Maintenance Services:
30,000 mile service - $455 (Save over $150 from dealer price)
- Inspect drive belts
- Oil change (Add $10 for Synthetic Oil)
- Replace engine coolant and inspect system and hoses
- Replace/Clean air filter depending on what intake you have
- Replace brake fluid
- Inspect brakes and system
- Rotate/inspect tires
- Replace transmission and rear differential gear oil
60,000 mile service - $610 (Save over $100 from dealer price)
- Spark plug replacement (stock or one step colder)
- Replace fuel filter (For cars with fuel filter in engine bay)
90,000 mile service - $455 (Save over $150 from dealer price)
105,000 mile service - $600 (Save over $200 from dealer price)
- Replace timing belt - $120
- Replace drive belts - $32
Add in the following for another $275!
- Replace water pump
- Replace Cam seals
- Replace AVCS Fittings (in AVCS equiped vehicles)
120,000 mile service - $610 (Save over $100 from dealer price)
- Replace fuel filter (all cars)
Happy Holidays from all of us at EFI Logics!
EFI Logics.com
8 Sympaug Park Road
Bethel, CT 06801
Phone: 203.748.1115
Email us through our website
EFI Logics.com / Facebook /Our Packed Interactive Dyno Database
Subaru / Porsche / Mitsubishi / Ford / GM
Banned
Discussion Starter #4
Are you running similar deals on alignments as well? Thanks!
Our normal price for alignments is $125 - we can do $105, however that is the base price - if the car needs hours of work, it will go up from there...
What about compression test + DP installation + Tune?
Send us a PM and I can give you pricing on that!
- Pete
1 - 4 of 4 Posts
