I am running 93 octane.
Guru said:Well the total price for our downpipe, Blitz SUS and the Turbo XS HPBC is $750. Now I would probably recommend and SBC-id instead of the manual boost controller. THis way you have a boost gauge in there. I'm doing that tomorrow.
As for the Noob's question, the reason the turbo is dying at higher RPM's is that the turbo can not deliver any more boost. It is completely maxed out at and starts delivery less and less boost. By redline I'm only getting around 13 PSI. The engine management is crucial to tune your AF mixtures and also your timing. It is crucial when changign turbos and of course fuel setups. We are doing some more tests tomorrow and will be sending our injectors and fuel rail to Japan for Power Enterprise to hopefully some up with a nice 800-880cc injector for us.
You are right when you believe that with a higher RPM and more exhaust gases, the turbo should deliver more boost. This is the theory of a positive feedback system. But the problem that is occuring is that the turbo itself is too small to provide 17 psi at redline.shoeeater said:NOOBIE ALERT!!!!
According to what I know about turbo's (not much) is that as the RPM increases the extra gas being pushed through the turbo should be able to increase the boost up to the desired level and keep it there as long as the turbo has enough waste gasses running through it? I know this obviously is not true because of those plots. Why does this happen?
Its more than just inertia, larger turbos have large exhaust wheels and sometimes larger a/r exhaust housings. This means less exhaust velocity (worse spool), but better flow. IME, the hot side of the turbo has a much larger impact on spool than the size of the compressor wheel.jeffsti said:It will also produce more lag because of inertia. It will take more exhaust gases to get the larger turbo moving. But once it does get going, it can provide unbelievable boost all the way to redline. You will notice how the torque curve will be flatter instead of dropping off before redline.
Jeff
