1 - 4 of 4 Posts
Does anybody else have this noise like scratching the window when opening and closing it? Also the window seems totaly loose when half open and it make a clunk noise if aI hit a bump or even brake fast.
I`m going to take it t the dealer soon, and i need some feedback about oast repeir for this issue I have.
I owned a 2004 WRX for a year and, It had same problem after the 10K miles in the odo.
Thank you guys .
same here.. it usually makes noise when it has water in it.. since the window has no frame, it moves around a lot hence the noise when going over bumps
most likely you have some loose bolts in the window assembly.
pull off your door cards and tighten them up. .
Discussion Starter · #4 ·
I`m ready to do this same thing, but if is something that other people are having I want to see the warranty working for this. My window it has a very ugly scratch on the top end, and the loose hardware that you are saying it migth have done it .:(
1 - 4 of 4 Posts
