1 - 5 of 5 Posts
Hello, What is the best/recommended way to drain gas from tank? 2012 sti sedan
I've read some couple methods so far , going through the fuel return line or old way of siphoning.
Thanks!
Well the best way to do it would be to open the tank from the fuel pump access point and drain the fuel out through there.
at least the less messy way :) there is a drain on the bottom, no? Just damn hard to get it to exit where you can catch it though :)
Thanks @Jay11STI , I may have to go this route. Would you know where the fuel pump access is? Is it under the rear passenger seat ?
Yes sir it is.
One small piece of advise, it will really help if the tank isnt full up to the top. As in you just filled up to the max and now have to open up the tank. Get some rags/mats just incase.
1 - 5 of 5 Posts
