1 - 15 of 15 Posts
Is it worth ordering a new gasket when I do my DP install, or will I be good just re-using the old one.
Thanks!!!
isnt the stock gasket smaller then what you'd need for a 3inch dp?
Discussion Starter · #11 ·
So, just the top gasket needs replacing? THe Cobb instructions call for re-using the donut gasket off the stock DP. Is this correct?
· Premium Member
FWIW, I resused my stock downpipe gasket about 5 times. rofl. I have a new one, but the old one wasn't leaking and still provided an awesome seal.
Now, with that said, it is always advisable to use a new gasket. I'm just pointing out that in some cases you can successfully reuse the old gasket.
t
1 - 15 of 15 Posts
