1 - 8 of 8 Posts
Hi all, I am sorry if topic was already discussed but i am unable to find it, so my question is:
Does anyone have downpipe blanket and is it worth it? :confused:
PTP has two options on their page, it looks like it has difference in constructive material for outer layer, which one will suffice daily drive.
PTP Subaru Downpipe Blankets | PTP Turbo Blankets
Go for the lava version between the two. I wrap my downpipe and use their lava turbo blanket. The downpipe throws off slot of heat and it’s not that far from your intercooler. First thing I did was get rid of the factory shield and put on the turbo blanket when I got the new 2019. Fully wrapped my ELH I put on with its up pipe as well. Helps tremendously with under hood heat management and keep the heat into the turbo for faster spool up.
Go for the lava version between the two. I wrap my downpipe and use their lava turbo blanket. The downpipe throws off slot of heat and it’️s not that far from your intercooler. First thing I did was get rid of the factory shield and put on the turbo blanket when I got the new 2019. Fully wrapped my ELH I put on with its up pipe as well. Helps tremendously with under hood heat management and keep the heat into the turbo for faster spool up.
Thanks. Yes, that was on my mind together with turbo blanket.
Future header i might leave bare as lots of discussion is between wrapping or coating, i didnt find so strong positive for wrapping and i will not do rewrap every year just to see if everything is ok with header. Regarding coating, here in my area is impossible to do professionally so that one is out, buying already coated is also not an option as I can read pre coated peel off after a year. ?
But wrapping the header BEFORE the turbo is what makes the larger performance difference. Covering wrapping DP is only to reduce engine bay temp, and radiation to intercooler.
FYI My Tomei header and DEI wrap went four years and 40K in all weather conditions before it needed to be replaced. I just re-wrapped it. It's not that hard and not that expensive. I wrap the top of my down pipe - till it gets near the the bend at the bottom of the car. I have pics - been meaning to make my first thread - gotta get the pics from Google Drive to Google pic to post I think.
Yes I know about that, but I am little bit skeptic after reading ton of conversations about that subject, few of them said although it is better to leave it bare than wrap it.
I am planning to get Tomei UEL as well and I dont know how good and efficient is their wrap which comes in the box!?
Get a ELH or don’t bother. ELH spool up quicker and help with heat balancing out of the cylinders.
HTML:
Difficult to say for sure, but the pictures and description on line look similar to DEI. I would plan to use it. If I didn't like it I'd just toss it and use DEI Ti wrap.
The advantages of wrap:
Inexpensive.
Easy DIY - even for replacement if and or when necessary.
Best performing on pipe "thin" insulation - by a wide margin.
The downsides to wrap are:
* Need to eventually replace.
* Fire hazard if oilled.
* Can promote aging of header material.
I worried about all these things before I built my car. After 4 years and 40K my "cheap" header is fine. I replaced the wrap - big deal. I maintain my car. I am careful not to get oil on it. (mind you tiny bit will just burn of as it would without wrap.) I inspect it when I do changes - which is quite often. Don't drive a car with a wrapped header if you can see smoke! Might be best not to drive any car that is smoking :)
Reactions: Fatghost and guzie
Discussion Starter #8
HTML:
Inexpensive.
Best performing the pipe insulation - by a wide margin.
I might even wrap it at a end and regular check will be done as usually I do, after some time I will see how wrap is holding and condition as well.
Heat management is now my first task, to eliminate as much as possible.
Nice one with smoking :D
UEL or stock ;)
1 - 8 of 8 Posts
