21 - 40 of 409 Posts
Discussion Starter #23
More on the exhaust. The exhaust does not reverberate in the neighborhood. WOT is loud but not annoyingly loud. Definitely no drone through any rpm or throttle inputs. It seems like the engine likes this exhaust over the last as it has better throttle/engine/turbo response. It has a hollow sound to it. It sounds like the rasp has a bit of reverberation and it does not sound like a weedwacker. It does not sound like your traditional subaru with EL manifold. Very unique.
Discussion Starter #24
I put the car on the lift to adjust the e brake after the rotor and pad install. I also finally installed the Thermotec velocity exhaust jackets I had ordered a few months ago. It brought down the under hood temps and the turbo spools slightly quicker to the effect that I was hitting the rev limiter sooner than what I was used to.
Discussion Starter #25
I replace the pcv, perrin turbo inlet+maf hose, and grimmspeed aos. I started to have oil in the intercooler and didn't see a reason to have remain installed. The Samco turbo inlet replaces the Perrin stuff. It started to rip from the bottom due to chaffing. The Samco had a port to plug in the cranks pcv. I wanted to plug the pcv electrical plug back on but the hose was too thick, so it remained off. It was hard to install the venair maf hose to the turbo inlet.
Discussion Starter #26 (Edited)
I finally got off my lazy butt and installed these rear lower Cusco Power Brace I got from Rallysportdirect.com months ago. Noticeable difference in steering feel and response. I guess it alleviated some of the chassis flex in the rear.
It was easy to install. It requires cutting the plastic fuel tank protectors. A Dremel tool is needed to speed up the process. Shears would have torn up the plastic.
Discussion Starter #27
I took my car to the base auto hobby shop to try to get my caster bushings more evenly set and to get the transmission bushings and mount swapped out. What I really need to do is get an alignment done. Anyways, I swapped out the stock transmission mount with the STI Group N and AVO Turbo polyurethane transmission mount cushions. Upon removing the transmission mount, I had discovered that my mount is actually broken on both sides. I was wondering why I have been miss shifting, even with the pitch stopper installed, because it wasn't doing this before. NVH slightly increased but not to the point that it's annoying. I didn't get the gear whine everyone was reporting after they did the swap. I took it to the freeway and shifts are cleaner and solid. The car has over 60k on the odometer and I'm slowly getting some maintenance done. Next will be swapping out the stock radiator and hoses with a Koyo and Samco hoses. I'll get to installing the Mishimoto oil cooler kit with thermostat, too.
Discussion Starter #28
I'm starting to enjoy more of the car after replacing the mount and bushings. It was like driving it for the first time. But this time, the shifter is doing what it's supposed to, get in gear! I might have to look into a 2015 STI steering rack swap. Twisty roads are much more fun to drive now with a lower chance of mis-shifting.
Discussion Starter #29
After trying several combinations of seat mounts, I found a combination that fits well for my height. I removed the Wedge bracket and replaced it with a newer version of Sparco bracket. It has better mounting slots to mount bigger/wider seats. Also, to make up for my height, I got a set of OMP tall side mounts. I now have a much better field of vision. Thanks to Jeff at Planted technology for helping me choose a combo that would work with me, even though my new set up didn't have any Planted stuff. I unfortunately had to removed the Planted side mounts I had, which were too low for me. Excellent customer support!
I put together my radiator upgrade. Before install, I went ahead and got the Mishimoto pnp fan shroud. It will have samco hoses and the whole assembly is ready to drop in.
Discussion Starter #30
Just installed the Mishimoto thermostatic oil cooler kit. It's 65 degrees in SoCal and in traffic, coolant temps hovered around 180-183. Before they would be around 190-197.
Discussion Starter #31
Cleaned most of the carbon off of my exhaust tips.
I love how this exhaust has two different personalities. Quiet when I need it, and loud when I want it. It almost make my car sound exotic like.
Do you know how the dimensions compare for the Synapse Diverting valve versus the stock valve. With my GS TMIC it is already a close fit for the hood and I am not sure the Synapse will fit.
Discussion Starter #39
CNY_STI,
It won't fit. I've tried. It will hit the intake manifold because the sheer bulk of the Grimmspeed and steep mounting area.
CNY_STI,
That sucks...everything I have read makes it sound great...might have to look into a Turbosmart Kompact then:(
Thanks for the hands on experience.
