361 - 380 of 409 Posts
Discussion Starter #366
Replaced the header armor with header wrap on the collector pipe. The constant removal, heat cycle, and airflow blew out the heat insulation off the header armor.
Discussion Starter #371
After installing my STI belt cover off of a STI Forester, the extra mounting hole had been bugging me. Luckily the mounting bracket off of a Forester fits, too. Now, I need to get another bolt.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Discussion Starter #374
The welds are pretty. The top fitting, I guess, is for the turbo inlet. But the fitting looks bigger than any port on the turbo inlet. The side fittings appear to be for the heads and the block. The lower drainage fitting has to go drain back into the block somewhere. As for mounting, my guess is probably on the strut tower by the turbo.
