1 - 7 of 7 Posts
Hey all I've recently tuned my load comp to within ~2-3%
I'm running a catless down pipe, AEM air intake and have a built motor with a compression ratio of 9.5:1
I've boost tested my car before and have no vacuum leaks
1.Is this load comp ridiculous and would it indicate i have a mechanical problem. I know that the fuel stumble problem can cause some really high squares. But i feel like this is excessive
Colorfulness Rectangle Font Parallel Symmetry
2. Are there mechanical changes i could make to improve the situation ?
3. What would i need to change in the tune for the below component; And would this help ?
4. Are load comp tables on or off in open loop?
Thanks to anyone that anwsers
I ended up deciding to start over and 0r'd out the load comp table to do maf scaling again
This time round I even rescaled it (removed low and high voltages that never get hit
Rectangle Slope Font Parallel Plot
I don't know if this will fix my problem but i can say without a doubt the maf scaling is dialed in extremely well
Rectangle Slope Line Font Parallel
1 - 7 of 7 Posts
