Do I have a bad wide band?
1328 Views 11 Replies 6 Participants Last post by  five0three
Here is my log of a wide open pull.
https://docs.google.com/spreadsheet/ccc?key=0AigyOs5mkGORdGo0UGJ0aUU3bE9UNFpMeDd5NThQY2c&usp=sharing
here is a video of my wideband during this same pull (2500-4500)
https://www.youtube.com/watch?v=XkOT3n-z48g
sorry, cant get it to embed for some reason.
I would think with A/F's this high, i would be knocking and pulling timing like crazy
Car:
2013 STi 5 Door 4500 miles
Mods:
Killer B Holy header/up pipe (coated and wrapped)
Perrin turbo inlet
COBB sf intake with box
TGV Deletes
Invidia catless DP
SPT catback
DW 65c pump
protune
I set up a fuel pressure gauge and (although its a bit bouncy) it seems that my fuel pressure is where it needs to be. 43.5 @ idle with FPR vacuum line disco's and capped. 38ish at idle with FPR under vacuum. Rises 1:1 under boost as it should.
Ive done a boost leak check and a vacuum test. No leaks. car runs smooth. Im really scratching my head here. The car has been down for almost a month now because I dont want to run it with things being this lean. With the way this datalog looks, I would think that maybe my wideband is faulty. Any advice?
1 - 12 of 12 Posts
uhhhhh,..,...
log isnt public. cant see it.
where is your wideband mounted?
if that is "real"... that is scary lean.
open log to public.. how far down is the bung for the wideband?
Do a search on you tube for aem wideband test. You will see a movie that shows how to test it.
sent from space.
made public. The bung is about 4 inches from the turbo.
Ill do that test tomorrow. Would my sensor being too close to the turbo cause a lean reading or the opposite?
The closer to the turbo the richer.
sent from space.
Wouldnt i see knock learn and knock feedback in the log if things were actually that lean?
Have you checked to make sure none of the wires on the rear of the actual gauge have fallen out of their clips? I had the orange wire dislodge itself and it showed stupid lean numbers (16.0 and above). Took us 8 hours to finally trace it back to a loose (I think orange?) wire on the gauge. Pushed it back into place and it read normal.
Do a free air calibration then try it again. Chances are your O2 sensor is reading funky. It happens a lot more frequently when it's that close to the turbo, as it's exposed to high temps and possibly baked some carbon on there. Either way, from experience I can tell you they fall out of calibration pretty quick at 4inches. Recalibrate and if it gets better, consider moving it a little farther from the turbo. Hope this helps :)
On an AEM there is no free air calibration.
Check the wires.. do the wideband test.
Here:
what do you guys think of my datalog?
1 - 12 of 12 Posts
