I have been running this "pieced together" DIY brake cooling set-up for 2 years and have had no problems. The results are AMAZING! I spent a lot of time researching and sizing up different options and the end result was a great success. One of the most aggravating things during my journey was the lack of info and how scattered it was. I wanted to start a thread that had a lot of information for anyone who was interested in setting up brake cooling for their GD-Impreza. In addition to a step by step "How-To" with pictures of my own set up, others are free to share their own set up as well. The more information in this thread the better. I can link any and all posts that may be relevant or helpful in my first post so that information is easier to find. Hopefully this will become a "STICKY" so that information is even easier to access.
Anyway, without further adieu, here is my set up and how I did it.
First is the entry of the air into the front bumper. I used the OEM Fog covers as a clean and OEM looking brake duct. I modified them to accept a 3" High Temp Silicone flex hose, which was my size and hose of choice when performing this mod.
Heres how I modified the Fog Covers.
Parts/Tools needed.
OEM Fog covers
Sandpaper (320/400 Grit)
Dremel with cutting and grinding bits
Box Cutter / Razor Blades
Super Glue
JB Kwik Weld Epoxy
Aluminum Ducting Tape
Painters tape
Krylon Gray Primer
Krylon Flat Black/Semi Flat Black
Drill and Drill bits
Home Depot PVC (Thin walled) 4" to 3" Coupler/Reducer.
This is how it looks after I trim it to fit flush against the odd shaped funnel in the OEM Fog cover.
I also sanded the back of the fog cover in addition to grinding a small grove at the exact contact point between the PVC coupler and the back of the fog cover. This allowed the modified edge of the PVC Coupler to sit in a channel and almost clip into place. This also provided more surface area and contact between the two so that the glue is more effective.
After the Super Glue
I then added JB Weld Epoxy to add some more strength and rigidity to the structure.
After the Epoxy
And I decided to be OCD and add more strength and rigidity by applying Aluminum Ducting Tape. This stuff is awesome.
After that I realized there was a sealed area that would trap water from the rain or car wash. So I drilled a few holes so that the water would drain out of the pocket. (these should have been drilled prior to gluing the coupler in place but I didnt realize it was necessary until after I had them glued, epoxied and taped down
This step is strictly for aesthetics. Lastly I taped up everything but what I wanted to be Black and primed and painted it.
The final step is a non reversible one that to me is not a problem but to others it may be. You will NOT be able to run OEM fogs after this modification is done to the bumper. On the OEM bumper there is a Rectangular "Tunnel" where the fog lights mount to behind the fog covers. That tunnel hinders the ability to install the covers after this extension has been added. So, In order for this to fit on the bumper you must do some CAREFUL trimming of the tunnel in the bumper. Here are a few pictures. FYI The only way to avoid doing this is to purchase some after market fog covers that have the extension molded into the piece and maybe they will be able to fit better without doing this.
This concludes the first Step in the Brake cooling set up.
Next was the hardest part to figure out due to the clearance issue on the inside of the subframe and engine compartment. The 3" high temp silicone flex hose would have to be routed through the bumper, into the engine bay(near the header and up pipe), and then into the wheel well, along side the axle and tie rods, where it would be routed to the hub or to be positioned to direct air at the back of the hub. (both of which are very effective)
Anyway. The solution was found when I stumbled upon a guy who makes the Roo Ducts. Randy Zimmer himself, the man, the LEGEND! I found his web page showing the progress of his invention that he was slowly working on and field testing. Well I decided to contact him and sure enough he was very helpful and sold me a set of his Carbon Fiber ducts that were a "God Send." His piece allowed for the hose to go through the bumper, by-pass the engine bay completely and enter the wheel well in the lower inner most corner where it mated to his piece. His ducts were shaped in such a way that they allowed clearance of the wheel at full lock and still had plenty of volume inside to move a significant amount of air. It protruded into the engine bay as much as possible with out having any issues what so ever. He also designed it to have 2-3 very solid mounting points to allow for a very rigid installation. The end result is as follows.
Here are the pieces off the car.
Fitted up by hand. (trimming of the inner fender liner is required and very easy.)
Here is a picture showing the areas needed to be trimmed. Self tapping screws were used after a small pilot hole was drilled in the areas shown. You must first do a little test fitting and drilling of holes in the brake duct in order to line up the holes in the right spot. You also have to drill an access hole at the bottom of the duct to be able to install a screw on the inside back surface since that is the only way to mount the bottom of the duct. The hole can be covered with any tape but is not necessary since air will still move through it with no issues.
The last piece of the puzzle was easy to find and infact was the first thing I purchased and installed. The Backing plate which I purchased from Quantum Motorsports. These can be purchased from a number of different vendors and serve as a direct path to the center of the hub and brake rotor where the hottest point is. I personally did not want to just remove my OEM backing plate due the fear of the Lower Ball joint rubber Boot melting since it is so close to the rotor. I decided to custom cut the OEM Plate to allow for flush fitment of the Quantum piece. This way the piece was functional and my suspension parts were protected from excessive heat from the brakes.
here are some pictures
I hope this was helpful. I can tell you that I have not experienced brake fade at the track at all, ever since I performed this mod. My brakes are very predictable and effective lap after lap on some of the hottest days.
Parts/Tools needed.
OEM Fog covers
Super Glue
JB Kwik Weld Epoxy
Painters tape
Krylon Gray Primer
After the Epoxy
