While under my car today I happen to look at my rear differential and noticed where the rear axels meet the diff there seems to be a leak. Both right and left axle collars are covered with black grease(pictures below). I inspected the boots on the axles and all were in good condition not containing and tears or holes. I believe it to be gear oil that has gotten dirty....What do you guys think worn out/damaged diff seals? Any help/ideas are appreciated- Car: 2008 STI
Anyone have experience changing these seals? Can the axles be removed and a new seal set in or is it necessary to remove the entire differential. Or am I going to have to pay a visit to the stealership?
You'd unbolt the lower knuckle bolts, then pop the axle out of the diff and swing the knuckle out far enough for the axle to come out fully. Support them with coat hangers or something. After that, changing them is pretty easy with a seal puller and a dead blow to tap them in.
Thanks for the heads up. What type of movement should I be looking for? Should I perform the check before dis-assembling the suspension components to remove the axle?
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
IW STi Forum
