1 - 1 of 1 Posts
· Premium Member
We have a huge stock of defi gauges right now. We have EVERY blue racer and Amber Imperial BF that defi makes.
Defi BF Series Amber Boost Gauge Psi (Imperial) - MSRP 256 Your cost 243.20
Defi BF Series Amber Exhaust Temperature Gauge (Imperial) - MSRP 299 Your cost 284.05
Defi BF Series Amber Fuel Pressure Gauge (Imperial) - MSRP 299 Your cost 284.05
Defi BF Series Amber Oil Pressure Gauge (Imperial) - MSRP 299 Your cost 284.05
Defi BF Series Amber Oil Temperature Gauge (Imperial) - MSRP 224 Your cost 212.80
Defi BF Series Amber Water Temperature Gauge (Imperial) - MSRP 224 Your cost 212.80
Defi Link Controll Unit II (REQUIRED TO RUN BF GAUGES) MSRP 115 Your cost 109.25
Features Include:
- Compact Design – 52mm (2 1/16th”)
- Advanced Stepping Motor Technology – full sweep 270 degree movement with smooth, accurate and precise movement.
- Electrical Type – all meters and sensors are electrical type, meaning sensor is remote mounted. Self diagnostic function to ensure sensors and meters are functioning properly.
- Blue Illumination – blue LED illumination for a crisp and vibrant display.
- Red Arrow – easily visible during the day or night.
- Semi- Black Face – face/ dial is invisible until the meters are turned on.
- Adjustable Outer Position Bezel – allows the user to set a warning point manually.
- Outer Pod and mounting stand – ABS Plastic pod and metal mounting pedestal are included.
- Opening/ Closing Ceremony – Unique opening and closing ceremony when gauges are turned on and off.
- Stand Alone Unit - Does Not Require use of DEFI Controller Unit II.
Defi Blue Racer Boost Gauge (52mm) MSRP 192 Your cost 182.40
Defi Blue Racer E.G.T. Gauge (52mm) MSRP 224 Your cost 212.80
Defi Blue Racer Pressure Gauge (52mm) MSRP 235 Your cost 223.25
Defi Blue Racer Temp Gauge (52mm) MSRP 160 Your cost 152.00
Defi Blue Racer Voltage Gauge (52mm) MSRP 128 Your cost 121.60
ATI Center Clock Gauge Pod works with 52mm or 60mm Gauges - 139.99 Shipped
MB 52mm Single Gauge Pods mounts at the bottom of the drive A-pillar - 68.00
MB 60mm Single Gauge Pods mounts at the bottom of the drive A-pillar - 72.00
If you purchase 2 or more gauges you will get 10% off retail (MSRP * .9 for all of you who are as bad at math as me :) )
All Prices INCLUDE SHIPPING inside the 48 states. Please pm for a quote to Canada, AK, or HI.
Please let me know if there are any questions
Thanks
Rick
801.619.1779
[email protected]
AIM: RickatRSD
1 - 1 of 1 Posts
