For Sale in Pgh, 15203
Used - Excellent Condition
$25 dollars + shipping to your door - PayPal or make reasonable offers
Sale does not include gauge. Also..does not include blank but that can be that can be worked out if desired.
From Subispeed about their product:
Highlights: Great fitment and design matches your 2015-2020 WRX or STI’s interior Black powder coated steel, no cheap plastic Installs with 3M double sided tape or optional screws Easy way to add a cluster for 52mm gauges Mounts under AC controls to keep your Subie’s dash clean Skillfully crafted by Cubbypod in the USA MONITOR YOUR PERFORMANCE WITH CUBBYPOD’S DUAL 52MM GAUGE POD The Subaru Cubbypod line has expanded to cover the 2015-2020 WRX & STI and we here at Subispeed are excited to bring it to you. If you’ve been searching for a clean mounting solution, look no further. Whether you want to monitor your car’s boost and oil pressure at the race track or keep an eye on your car’s performance while driving around, this pod allows you to mount dual 52mm gauges where you’ll easily be able to see them. SIMPLE TO INSTALL & MATCHES YOUR WRX OR STI’S INTERIOR This gauge pod mounts underneath the AC controls of your Subie with pre-applied 3M style double sided tape. You can also choose to mount the pod with screws. It even leaves you room below the pod for small items. With wiring that can be routed to keep your rubber mat in place, wrinkle black coated steel, and excellent fitment, this pod discreetly blends in with the interior of your car to maintain a clean look. NOTE:Your cigarette light plug will be covered by this pod. You will still have access to other cigarette light plugs such as in your center console.
