bump for help!
Thanks! if the piece comes painted I guess $160 is ok.Yeah the center piece is a tricky one ... i always thought i would break it at some point but thankfully never did. Installing is easy as pie no need to worry about cracking it while pushing it in place.
salvage yard is your best bet or maybe the buy&sell section on iwsti/nasioc?
I'll see if i can look up the P/N
EDIT: p/n from what i can see on my partlist is 91121FE230PG it comes pre-painted cause this number is for the blue mica (wrb) color (other ones are different numbers) price on the list is upwards of 160$ so be prepared to pay alot for this piece of plastic ... as with all the plastic pieces on the car for that matter. If i where you contact the DS for price and then look second hand to see if you can save a couple of bucks.
Only pic i found when googling the part number. As you can see it comes without the badge.
Image Link
Btw i'm so jealous of that S204
If need be i can put up a pic from the page in my partlist (02-06' but that doesn't matter cause 06-07 is virtually the same)
I replaced mine and it was simple to push the new one in. If I recall correctly there are 2 clips on the left and right sides; just make sure you slide it in evenly to engage all 4 clips.ordered the new piece!
Im afraid im going to crack it when i push it in... do you push in the top first or bottom first?
Just go to Subaru Genuine Parts.com and enter the part number into their OEM part search to verify.Hi
Can you please confirm the P/N was 91121FE231PG?
Cheers
