1 - 3 of 3 Posts
Which fuse is a constant 12V for the 2018 STI? I'm adding a DRL and I want them to be on when the STI is on.
Thanks
You don't want constant 12V, that's exactly what it means the fuse will constantly have 12V regardless if the ignition is on or off, you want to find a fuse that get power only when the ignition is on, otherwise the DRL will be on when you shut off the car or get yourself a DRL module.
1 - 3 of 3 Posts
