1 - 18 of 18 Posts
**WORK IN PROGRESS**
TODO: video (what do you guys want?), finish testing out all the variables and what they measure/how useful they are, pictures of each of the main displays, and whatever else people need/want.
What it is:
An OBD II/Nissan ECU variable monitor.
What it is not:
An ECU code reader/clearer (it will however tell you how many codes you are throwing)
A dynometer like device like a with accelerometer.
Testing background:
I purchase my unit used from a member of nasioc who had it installed on his bugeye wrx for about 11k. The unit is from the first run of production. I have an 04 with no engine mods.
What comes with it:
1)Greddy Informeter-mine is white. Some come black.
2)Faceplates-these are pre-cut pieces of paper in various colors. Of note are pink, black, white, and dark blue
3)Instructions (mine came in Japanese, but they have English ones here: http://www.greddy.com/img/PHP/products/pdf/684.pdf)
4)An OBD II connector
5)An older style Nissan connector
6)A cig lighter style/12v power adapter
What will it monitor on our vehicles (04 sti):
There is a list that comes with the instructions that shows the functions that work with each car. Unfortunately this came in Japanese.
Things that are true for each variable:
-ability to view the peak (I believe it is peak positive)
-warning values medium and severe
-in some displays you can choose between 3 display styles per var
---now: 130
---now/peak: -.16 / .92
---bar: a bar graph that moves from left to right
---these all light up yellow or red when they reach the set values
-certain percentages of calibration can be set up for these variables
---ignition timing
Things that are set globally:
-audible buzzer on or off
-warning light on or off
The list:
- Speed - current speed in kph or mph - I guess an audible warning could be useful for drag racing to see if you met your target or perhaps on a road trip to keep you from exceeding a certain speed.
- Tacho - tachometer - drag racers will want this - dual stage warning light/buzzer
- Water - water temperature - semi useful to see how long your car warms up/when your car is warmed up - mild warning is set at something like 205 initially-you'll probably want to change that
- Ignit - igintion timing
- Injct (preset at 40 for red)
- Intak - intake temp - how is that intercooler water sprayer button working for you?
- Batt - voltage - the inital warning level seem a bit off for my car and it kept lighting up buzzing
- A/F- C
- O2R - doesn't work - constantly reads high
- Airflv - air flow voltage
- In-mf (boost gauge) - displays in bar and cannot display in psi - useful because it can display peak boost
note: i think it only goes up to 18.5 psi due to a limitation in the ECU.
- O2 - useless - not wideband
- Throt - throttle position - I can't figure out where this is useful, I'm sure someone else will. Maybe if we didn't have a throttle by wire it would be useful?
- WGV1 -
- WGV2 -
- AT-FL
- Gear - no reading
- 4WD - no reading - might work on an evo or a later model subaru (?)
The Displays:
single round
round plus others
twofold
threefold
round/bar
Install:
Plug it in and turn the car on. Then select Subaru from the maker list.
Customizable faceplates:
These are pieces of paper and really simple to install.
Mounting Ideas:
I used double sided 3M exterior tape. This stuff is pretty darn sticky. I'll get back to you if it falls off. I used the exterior stuff.
The instructions also mention that you can mount the unit with a cell phone holder.
I've seen it mounted over on the steering column like this:
I've also seen it mounted to the left near the A-pillar like this:
He used a blitz powermeter ID mount, I believe.
Powering:
Powering via the OBD II port does not seem to work for me. I have heard that on other cars you can power it this way. The wire to the cig lighter plug is the hot wire. A ground wire is included on the OBD harness (?)
Update speed:
-Boost
-Tach
I chose to power mine off the cig lighter until I could go to the store to get a fuse piggyback unit. I then pluged this into the unused rear whiper blade slot and wired it together.
Pros:
-Flipping through the various display modes with the up and down buttons is pretty cool.
-Looks pretty good.
-Monitors several useful variables.
-Peak monitoring of all variables is very nice (Especially Boost).
Cons:
-Display is difficult to read on a very sunny day. You are able to change the colors to make it easier but I would have liked to have a day and a night mode or multiple "profiles".
-No EGT...but that's because there is no EGT probe on the car to begin with
-No A-F ratio...but that's because we need a wideband gauge. If I were doing real tuning I would get a real A-F meter I could trust anyways.
-My informeter freezes (weird screen artifacts, double vision, lack of color, etc.) if I turn it on with the car off but the ignition on accessory and leave it like that for about 5 minutes. This isn't cool for those who like to run their stereos and would like to use the informeter to watch the voltage. You can fix the freeze by unpluging the OBD plug, pluggin it back in a starting the car. I can also get it to freeze by repeatedly using the IC spray. These may be because my unit is used...maybe not.
Discussion Starter · #2 · (Edited)
The install:
Add-A-Circuit
Add-A-circuit installed (note that the coin door did not want to shut with it in this place...it did eventually work though.):
Dongle (I love that word) (Note how the plug fits up in the OBD spot):
I ran the wire along the seam and it tucked in nicely:
Originial installation place:
Why that didn't work so well:
More pictures:
The black unit would probably attract less theves:
Where it ultimately ended up(I used double sided sticky tape here but might get an L bracket from the hardware store later):
I ordered mine because of the picture mounted right in front of the cluster.
I will have mine in three days.. actually looking forward to it!
I got the black one!
Overall how do you like the unit?
Rating via 1-10?
I am not worried about EGT or things like that as I already have defi's...
W00t w00t!
-Nigel
A 7 or 8 I guess but that is only because of the freezing/locking up which may be due to my unit being used and all.
Looks good, I never thought about powering it from something other than the cigarette lighter.
As for the locking up problem that only occured to me once or twice I just thought it might have been something with the power connection.
Hope you enjoy it!
Lee
Just a heads up: The intake temp is read at the MAF, not at the intake manifold or after the TMIC. This just reads air temp after the filter and not charge temp.
I just got mine!
Couple questions for ya about the unit..
The dial that you can change the colors with.. this might only be MINE but when I change the colors from like yellow to green.. etc they don't really truely look like that color... yellow looks like a light green, amber looks blueish...etc
Just want to see if anyone else's is the same way..
Also the unit to me feels really cheap... :-( Flimsy persay...
Other than that it is pretty neat!
-Nigel
I am interested in this product. From everything I read, It locks up when powered through the cig lighter and water spray is used, correct? I have an '05 and I have seen someone with an '06 say they powered it through the OBD II port(eliminated the lock-up problem), and someone with a '04 say that did not work for them. Anyone know about the '05? Will wiring it through the fuse box as shown above eliminated the cig lighter/waterspray/lock up problem(if it is INDEED a problem)? Also, where is the best place to buy a BLACK one(not just price, but reputable, reliable dealer)? I know faceplates are available but I would prefer it to be less obvious from outside the car. Thanks to all in advance.
Discussion Starter · #11 ·
I'm sure the problem with freezing up is a lack of power regulation. I get this idea from my own project that relies upon the 12V power system on these cars. The cars actually put out up to 14V. 14V unregulated to a Microcontroller (chip) wanting 12V will mess things up (temporarily and possibly, but not likely, permanently). If you want to test it out and be perfectly safe you could add a 12V single output, non-adjustable, voltage regulator to the circuit. (http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=MC7812ECT-ND) They give off heat though and may need a small heatsink.
Discussion Starter · #12 · (Edited)
Here's an easier one to get a hold of: http://www.radioshack.com/product/i...ulator&kw=voltage+regulator&parentPage=search
Basically it'll take in any voltage up to 35V and make sure that it outputs something very very close to 12V. The voltages above 12V will cause it to give off heat, but I'm thinking that the highest you'll see from the car's electrical system will be 14.5V so you shouldn't need a heat sink.
As you can see the regulator has 3 pins. 1) voltage in 2) ground 3) voltage out. Read the spec sheet to see which pin is which and the wiring should be pretty simple.
Wow, awesome write up!! Though I dont have a Greddy Informeter, My blitz r-vit I color works exactly like your Greddy Informeter in terms of installation and functinality... Wish I could post some pics but got none right now..
i've just installed in my 08 sti, is very nice and smart but i don't know how accurate it is ...
anybody knows why this infometer can not read the speed ? linked by speed are trip, power, Gear Pos ...etc wich are not running :(
thx
1 - 18 of 18 Posts
