So, the manual consists of five pages. I will publish them all, with the google translation below it. Just to be clear: I do not speak Japanese
This manual has been valid in Japanese domestic use only
Support front kit installation / instruction manual
Thank you for purchasing this product. -This manual explains the installation, handling, and observance of this product.
・ Please read "Handling Precautions" carefully before use to ensure correct use.・ Also, keep this manual in a glove box, etc., and read this manual each time you have any questions.
The following marks are displayed for important points, so be sure to observe them. | What you must follow for your safety
△ warning
[Incorrect handling may result in death or serious injury] Safety and must be observed for the vehicle [Incorrect handling may result in injury or accident May be connected]
△Attention
※advice
What you need to know
Things to know
A warning
-Never modify or modify this product.
The product may be damaged and cause serious damage. -For safety reasons, be sure to stop the engine before starting work.
・ Be sure to tighten bolts and nuts.
・ Tighten the mounting bolts after mounting for 100km and if necessary, inspect them regularly.
Please do .
・ If any abnormality (abnormal noise, vibration, etc.) occurs while driving, immediately stop the vehicle in a safe place, check the mounting bolts, etc., and retighten. If the abnormality still does not improve, promptly inspect and repair.
Please go. Continuing to drive may cause damage to the vehicle or an accident.
-If the product receives a strong impact due to deterioration, damage, accident, etc., the original performance can be maintained.
Please stop using it immediately as it will disappear.
△Attention
-This product does not dramatically improve the marginal performance itself. Always try to drive safely
I.・ Do not use this product for any purpose other than the applicable model or for its intended purpose.
It may damage the product or lead to an accident.
・ If this product requires disassembly and maintenance, please install it at a certified factory of the Ministry of Land, Infrastructure, Transport and Tourism.
When installing this product, be sure to follow the relevant vehicle model service manual issued by SUBARU Corporation and follow the precautions in this manual.
-When installing this product, if the bolts and nuts are tightened outside the specified torque, the bolts and nuts may be damaged or loosened. Therefore, tighten the product in compliance with the specified torque.
※advice
-The Company is not liable for any direct or indirect damages caused by improper installation or handling of this product, resulting in malfunctions or other malfunctions.
-Please note that we cannot guarantee any defects in the product or vehicle that occur directly or indirectly due to the installation of this product.
・ For vehicle defects that may occur due to the installation of this product, SUBARU Corporation's vehicle credit
Please note that it may not be covered by the warranty.・ When replacing with this product, be sure to use SUBARU for non-reusable parts, consumables, oils and fats.
Using genuine parts
Please give me.
-The specifications of this product are subject to change without notice.
・ The data described in this manual may differ depending on the measurement conditions. -Installing this product may cause deterioration of ride quality and major changes in driving characteristics.
Installation procedure
1. Part number and applicable model STI part number
Part name
Support front
kit
Applicable model
GR Impreza
GH Impreza SH Forester Turbo Car A ~ YA Exiga Turbo Car A ~
Turbo car A ~
BL / BP Legacy Turbo Car A ~ VA WRX STI Turbo Car A ~
2. Finished parts
① Support arm front (RH / LH)
: 1 copy each
② Support chromen front
1 each 2 pieces
③ Spacer (D = Φ24, d = Φ11. T = 6) ④ Spacer (D = Φ24, d = Φ11.t = 10) 2 sheets
Select and use with or without flexible lower arm bar
⑤ Hexagon socket head cap screw M10 × 22
⑥ Flange bolt M10 × 25
⑦ Flange bolt M10 × 30 ⑧ Washer (D = Φ24.d = Φ10.5.t = 3.2) 1 piece
⑨ Installation / Instruction Manual (this manual)
* Please check the number of members first. In the unlikely event that there is a shortage or difference, the store where you purchased the product
Please contact.
3. Specifications
Reinforcing member for front cross member.
4. Precautions for installation
△ warning
To ensure safety, be sure to remove the negative terminal of the battery while the engine is stopped.
Please give me.・ Be sure to tighten bolts and nuts.
△ Note
-Installation of this product corresponds to disassembly and maintenance stipulated in the Road Transport Vehicle Law. Installation at a SUBARU authorized garage is recommended to ensure proper installation and functioning of the product.
・ Be sure to follow the service manual for the vehicle model issued by SUBARU Corporation and follow the precautions in this manual.
Please. Tighten in compliance with the specified torque. If tightened outside the specified torque, the bolts and nuts may be damaged or loosened.
5. Simultaneous exchange and reuse of unavailable parts
Replace self-locking nuts and flange nuts according to the service manual issued by SUBARU Corporation.
please.
6. Work procedure
Be sure to follow the replacement work procedure according to the service manual issued by SUBARU Corporation.
Support front kit components (mounting overview)
With flexible lower arm bar installed
④ Spacer 10mm
② Support chromen F
Without flexible lower arm bar
Flexible lower arm par bracket
③ Spacer 6mm
① Support arm FLH
⑧ Washer 3.2mm
LH side only
① Support arm FRH
△ warning
△ warning
△ warning
Securely attach the attached washer
please. If the mounting is not secure, the bolts and nuts may loosen even if they are tightened to the specified torque.
Be sure to tighten bolts and nuts to the specified torque. If the tightening is not secure, abnormal noise may occur or the running condition may become unstable, resulting in an accident.
To customers
△ warning
・ If any abnormality (abnormal noise, vibration) occurs while driving, immediately stop the vehicle in a safe place, check the mounting bolts, etc., and retighten. If it is still abnormal, promptly inspect and repair it at a SUBARU dealer (dealer). If you continue to drive as it is, it may cause damage to the vehicle or an accident.
Su.・ Mounting bolts should be inspected after mounting for 100km and regularly, and if necessary, retightened.
please.・ Do not use this product for any model other than the applicable model.
By installing this product, the rigidity around the front is increased against the input from the road surface, the input from the steering, and the input from the engine, but it does not dramatically improve the limit performance itself. Please drive safely as before the replacement.
note
-Installation of this product corresponds to disassembly and maintenance stipulated in the Road Transport Vehicle Law. Installation at a SUBARU authorized garage is recommended to ensure proper installation and functioning of the product. -Installing this product may cause deterioration of ride quality and major changes in driving characteristics.
Spartan Technica International Co., Ltd.
3-9-6 Osawa, Mitaka City, Tokyo 181-0015 TEL: 0422-33-7848 FAX: 0422-33-7844
