I grabbed Ziggyrama's stage 1 map AE5I910V
https://www.romraider.com/forum/view...hp?f=27&t=8190
& Transferred the changed tables to my ROM AE5L500V
[missing] (F1520) IMRC CIRCUIT MALFUNCTION
[missing] (F1519) IMRC STUCK CLOSED
[missing] (F151S) STARTER SV.,'ITCH LOVI INPUT
[missing] (F1491) PO.' (BLOV„'8Y) FUNCTION PROBLEM
[missing] (F1443) VENT CONTROL SOLENOID FUNCTION PROBLEM
[missing] (F141S) SECONDARY AIR PUMP CIRCUIT SHORTED
[missing] (Fli53) FRONT 02 SENSOR RANGE-/FERF HIGH 81 Sl
[missing] (Fli52) FRONT 02 SENSOR RANGE-/FERF LOVI 81 Sl
[missing] (80638) THROTTLE ACTUATOR RANGE-/FERF
[missing] (80607) CONTROL MODULE PERFORMANCE
[missing] (80464) FUEL LEVEL SENSOR INTERMITTENT
[missing] (P0457) EVAP LEAK DETECTED (FUEL CAP)
[missing] (80448) EVAP VENT CONTROL CIRCUIT SHORTED
[missing] (80447) EVAP VENT CONTROL CIRCUIT OPEN
[missing] (80442) EVAP LEAK DETECTED (SMALL)
[missing] (80418) SECONDARY AIR PUMP RELAY A
[missing] (FOIS3) FUEL TEMP SENSOR A HIGH INPUT
[missing] (FOIS2) FUEL TEMP SENSOR A Lav,' INPUT
[missing] (POISI) FUEL TEMP SENSOR A RANGE-/FERF
[missing] (80139) REAR 02 SENSOR scav.,' RESPONSE
[missing] (80126) INSUFFICIENT COOLANT TEMP (OPERATION)
[missing] Timing Compensation Per Gear Activation (Load)
[missing] Timing Compensation Per Gear Activation (RPM)
[missing] Timing Compensation Per Gear (5th)
[missing] Timing Compensation Per Gear (4th)
[missing] Timing Compensation Per Gear (3rd)
[missing] Timing Compensation Per Gear (2nd)
[missing] Timing Compensation Per Gear (1st)
[missing] (80341) CAMSHAFT pas. SENSOR A RANGE/PERF
[modified] Checksum FIX
[missing] Idle Speed Target D
[modified] Idle Speed Target C
[modified] Idle Speed Target B
[modified] Idle Speed Target A
[missing] Requested Torque Limit 8 (Per Gear/Engine Speed)
[missing] Requested Torque Limit A (Per Gear/Engine Speed)
[modified] Target Throttle Plate Position Maximum (Requested Torque Ratio)
[modified] Target Throttle Plate Position Non-cruise (Requested Torque Ratio)
[modified] Target Throttle Plate Position Cruise (Requested Torque Ratio)
[modified] Requested Torque Base (RPM)
[modified] Requested Torque (Accelerator Pedal) SI-DRI%/E Intelligent
[modified] Requested Torque (Accelerator Pedal) SI-DRI%/E Sport Sharp
[modified] Exhaust Cam Retard Angle Non-cruise (AVCS)
[modified] Exhaust Cam Retard Angle Cruise (AVCS)
[modified] Intake Cam Advance Angle Non-cruise (AVCS)
[modified] Intake Cam Advance Angle Cruise (AVCS)
[modified] Advance Multiplier (Initial)
[modified] Rough Correction Range (Load)
[modified] Rough Correction Range (RPM)
[modified] Fine Correction Columns (Load)
[modified] Fine Correction Rows (RPM)
[modified] Fine Correction Range (Load)
[modified] Feedback Correction Minimum Load
[modified] Timing Compensation A (LAT) Activation
[modified] Knock Correction Advance Max Primary Non-cruise (LAM)
[modified] Knock Correction Advance Max Primary Cruise (LAM)
[modified] Knock Correction Advance Max Additive 8 (Knock Conditions)
[modified] Knock Correction Advance Max Additive A (Knock Conditions) (IAM)
[modified] Base Timing Reference Non-cruise (AVCS related)
[modified] Base Timing Primary Non-cruise
[modified] Base Timing Reference Cruise (AVCS related)
[modified] Base Timing Primary Cruise
[modified] MAF Limit (Maximum)
[modified] "F Learning #1 Airflow Ranges
[modified] CL Delay Maximum Engine Speed (Per Gear)
[modified] CL Delay Maximum (Vehicle Speed)
[modified] CL Delay Maximum (Throttle)
[modified] CL to OL Transition with Delay (Throttle)
[modified] CL to OL Delay/Switch SI-DRI%/E Intelligent [modified] CL to OL Delay
[modified] Primary Open Loop Fueling (KCA Additive 8 High)
[modified] Primary Open Loop Fueling (KCA Additive 8 Low)
[modified] Manifold Pressure Sensor CEL Delays
[modified] Manifold Pressure Sensor Limits (CEL)
[modified] Turbo Dynamics Proportional
[modified] Initial/Max Wastegate Duty Compensation (LAT)
[modified] Max Wastegate Duty
[modified] Initial Wastegate Duty
[modified] Boost Limit (Fuel Cut)
[modified] Target Boost Compensation (Atm. Pressure)
[modified] Target Boost Compensation (LAT)
[modified] Tartlet Boost Compensation (1st Gear)
Are there any of these tables i shouldn't be changing ? Or any concerns anyone sees?
I made a nice pdf the highlights the differences
Both roms are here for anyone interested
