21 - 30 of 30 Posts
Actually, I just got approved for ProTuner status... If you'd like, I can make you a map to address this issue. If you are satisfied with it, I can then finish the map the rest of the way as a customer. Let me know if you'd like to try that.
Discussion Starter #23
Let me think about this for a few days here and weigh my options. While I appreciate your offer, I'm almost thinking it would be better to have someone check the car out in person vs a remote tune, although I am quite curious if it's 100% related to a tuning issue, or if it's something more - I still need the vehicle drivable in the interim.
Hey Guys,
I've been trying to track down this issue and have I've no luck discovering what it is. I can't even get my tuning shop to give me a call back and work toward a resolution either, so I'm hopeful someone has some insight.
I just got my 2017 STI tuned, and there were no issues with it on the dyno. Tune came out great, except for when I got it home the next morning and realized that it has a cold start stumble every morning now. It only happens when it's cold for some reason. The car starts up perfect, idle is great, then literally after 20-22 seconds, the car bogs down and it nearly dies. This goes on for about 3-5 seconds, then the car corrects itself, and it goes back to idling perfectly fine. Hot idle is perfect. Drivability is great. Car made great power. No other issues or CELs with the vehicle. No idea what's causing this.
I have seen a few other random references to this same issue on 2016-2018 model STIs for some reason. I don't know if this is a change in the ECU or how they are tuned? Anyone have any ideas? I'm suspecting this has something to do with the TGV delete, but, those have been being removed on these engines for how many years now without issue. I have also verified the functionality of the stock baro sensor - it is still plugged in and working.
Car has only 10k miles on it, and runs only 93 fuel, compression test came out great when I checked it. Mod list as follows: IAG air pump delete, IAG tgv delete, Cobb intake + box, Cobb turbo inlet, Cobb upppe, Cobb downpipe + full catback exhaust, Perrin EHL, Cobb EBCS, Cobb 20g turbo, Cobb fuel rails, Cobb fuel injectors (1050), Cobb FPR kit, Cobb parallel fuel line kit, AEM fuel pump, Cobb AOS, and Cobb FMIC. I think that's about it.
Assuming I can even manage to get ahold of them, can I somehow get my tuner to unlock my map so I can maybe find anther tuner to look at it? This is my first Subaru since my old 2004 WRX (which was open source). A lot has changed since my last experience.
Thanks in advance. Appreciate it.
Did you ever figure it out? I have the exact same issue...
Discussion Starter #26
Just an update -
I ended up having the car retuned by a different tuner this week and just got back home. Very enjoyable experience. He truly took his time on my car and the tune reflects this.
The cold start issue isn't 100% fixed yet, but it's probably about 90% better. I left a message for him a couple days ago, but due to memorial day weekend, I'll probably hear back next week at some point. Hopefully, he can resolve this 100%, but if not, it's still way better than it was. Before his tune, it was nearly dying for several seconds. Now, it's just a quick drop for a 1/2 a second and it pops back fine.
I know YamahaSHO offered to help, but I really felt better having someone view the car in person in case there was some noticeable issue somewhere or a problem.
At this point navin'swrxsti, I'd say it's likely tune related. I'm thinking mine was related to a tune as well judging from the results of the new tune. I'm hopeful that the issue can be 100% remedied here in the upcoming days/weeks, but even if it can't, it's still a night and day difference to how it was before.
Just an update -
Glad you got it most worked out. Do you mind saying who the tuners were. Wondering if we have the same tuner
Tuner should always be responsive which i found the most helpful as well.
Glad you were able to resolve most of the issue.
I think i would've taken up yamahasho's offer since you already dynoed and know your numbers.
Yamah is so active and responsive on this forum and has helped me with almost most of my threads of silly and complicated questions.
21 - 30 of 30 Posts
