1 - 10 of 10 Posts
Hey guys, I am soon going to purchase a new set of coilover.
(which one? haven't decided yet)
First off, I don't mind a bit harsh ride, I can live with 8k/6k with no problem and I still think it has room to improve the body roll.
I already have Cusco front and rear swaybar (22mm)
But since body roll isn't = bad, I don't know if I should try a set of coilover with stiffer spring rate or just stick with 8k/6k
I don't know if 10k/8k spring rate will be too much on street tires with swaybars (like RT615) and I only track 1-2 times a year.
Assume the new coilover damper setting are good for 8k/6k ~ 10k/8k
I was wondering will the 10k/8k fit my need better or 8k/6k because it will lose so much traction on street tires with 10k/8k?
I'd love to have a stiffer ride but traction and grip is what I concern with street tires :D
I know this is really depends on personal taste, but hope someone can come in and share their thoughts.
Thanks!
how about tires like Z1, R1R or RE01R?
Are these tires worth to get a higher spring rate?
or 10k/8k are really not needed unless I get R-comp?
(ps, I run -3 camber up front because I autoX sometime....)
Thanks!
If you are going to be tracking only 1-2 times/year then personally I would go with a softer suspension set up (8k/6k) like previously suggested. If your daily commute finds you driving on any rough/uneven/broken roads then 10k/8k will definitely not be pleasant.
If at all possible you should try to see if anyone around you will hook you up with a ride just to experience both spring rate set ups that way you can make an informed decision for yourself.
Goodluck.:)
I don't really daily drive my car and I kinda of think 8k/6k setup is totally comfortable
But since I only track it 1-2 times/year I don't know if it's worth to setup the spring rate for my track tires (R1R, RE01R)...
Since I use Z1 for my street tires and I run -3 camber up front for autoX
I don't know if 10/8k will be a better match for me :D
I don't need the car to be comfortable because I won't really drive it much on the road, it's like a weekend warrior only :D
Thank you very much!
1 - 10 of 10 Posts
