1 - 9 of 9 Posts
Yes, just go with the stage 1 and reset the ECU after your flash it. Give it like a week or a tank of gas to learn it. After, you can do some data logging and see if you are hitting boost target.
what others have said, and make sure you read your manual from front to back, its important, and you will be happy that you did, I know its exciting and you just want to install it, but take the time to
just my 00022 cents
Otter said:
I didn't reset my ECU after stg 1 flash, am I missing something?
You don't really have to reset the ECU after you load the new stage 1 or 2 base map. I do it so that the ECU can have a clean sheet of slate to work on. This way, if anything from previous(which I doubt) wouldn't get into the way of the ECU learning the new base map.
It's almost like putting in a new mod and resetting the ECU. This is the same process.
Wait, why would you having trouble either with boost creep, or not hitting full boost with a stock DP?
No offense man, resetting the ECU is kinda pointless, since the AP pretty much revamps your ecu, it cleans the slate so to speak, so it can work its magic!!
1 - 9 of 9 Posts
