Cobb/ID 1050X vs. ID 1000: how much of a difference is it really?
4.6K views 12 replies 7 participants last post by  Karlot
The coil latency will be different, as well as all the other trims they've provided from ID directly. No matter what you use, you need the appropriate data input for said injector.
As for the difference in possibly changing them... The ID1050 has more corrosion resistance, which is pretty desirable.
What’s the approximate max HP that the 1050’s can support on 93. And is it a must to replace the fuel rails? My end target is in the 400whp range.
owns 2019 Subaru WRX STI Base FP Green Flex Fuel
1050s can get you into the 400 range on both pump and e85. replacing the rails isnt necessary,
I’d like rails, but fitment seems questionable from that I’ve read, puts the lines too close to the TGVs. Plus I’m of the keep it simple stupid to achieve my goals lol
if you wanted rails, get IAG rails and lines, and you'd be good to go. though for pump gas and your power level, you are really just adding bling to the engine bay, oem rails/lines will support that just fine lol. you'll need injectors and a pump, if you track the car, maybe a second pump with a surge tank, but i dont think you said you were tracking it. so pump+injectors and you'll be good to go
And all of it is dependent on my custom DP build. If I can’t get past the CEL that the 19+ has when doing a DP, I might be at the end of my road. But I think I have a solution that is going to work for us 19+ guys
