1 - 20 of 26 Posts
Banned
Contact us for pricing!
The ECU tuner you all know and love. So easy to use anyone can do it! Get yours today.
Features:
-Larger, full color, higher resolution screen
-Monitoring of 6 paramters real time
-Interchangeable Faceplates
-Customizable multigauge display
-In vehicle mount, with on/off switch
-More power, memory, and speed
Contact us for Pricing
Haltech ECU Only
Platinum Sprint 500 - MSRP $854 - CONTACT FOR PRICING
Platinum Sport 1000 - MSRP $1359 - CONTACT FOR PRICING
Platinum Sport 2000 - MSRP $1814 - CONTACT FOR PRICING
Haltechs w/ Flying Lead Kits
Platinum Sprint 500 w/ Flying Lead Kit - MSRP $991 - CONTACT FOR PRICING
Platinum Sport 1000 w/ Flying Lead Kit (Short 4') - MSRP $1668 - CONTACT FOR PRICING
Platinum Sport 1000 w/ Flying Lead Kit (Long 8') - MSRP $1723 - CONTACT FOR PRICING
Platinum Sport 2000 w/ Flying Lead Kit (Short 4') - MSRP $2123 - CONTACT FOR PRICING
Platinum Sport 2000 w/ Flying Lead Kit (Long 8') - MSRP $2177 - CONTACT FOR PRICING
42 Autosports offers the full range of Motec ECU and Center Diff control products for your Subaru. If you need full and total control of your cars drivetrain this is the ONLY option for you!
M800 Plug-In ECUs WRX & STi
MoTeC M800 Plug-In ECUs are fully programmable, direct replacements for factory ECUs on a select number of popular vehicle models. Based on the M800, they control the latest automotive advances such as continuously variable camshaft timing and drive by wire throttle.
Complete with an OEM connector, M800 Plug-Ins are convenient and cost effective to install because they eliminate the need to rewire the vehicle. They simply plug into the factory wiring harness using the original sensors, ignition modules and fuel system. The units are built to operate with saturated drive fuel injectors.
Fits WRX and STi: most models from 1999 - 2008, however The ‘08 Subaru M800 Plug-In disables some factory electronics and is therefore not suitable for road use. Race and rally vehicles should be fitted with a MoTeC SDC3 to control the center differential.
MoTeC’s Subaru Diff Controllers (SDC, SDC2 and SDC3) are suitable for Subaru WRX and STi vehicles. They are plug-in replacements for the factory fitted Driver Controlled Centre Diff (DCCD) controller, fitting into the OEM box that is bolted to the steering column underneath the dashboard.
Will fit 02-08 WRX & STi
Banned
Discussion Starter #2
Re: Cobb Accessports, Haltech and Motec ECUs from 42 Autosports! Dont Forget Your Ext
To Order Extra-S Please click Here!
Extra-S
This is the OE Subaru Gear Oil that is run in the STi. We run this stuff in anything and everything that needs 75w90 gear oil and love it.
Each bottle is just over 1L.
These packages are setup to do the transmission and rear differential.
Synchro Magic
If you are having issues with synchro grind might we suggest a bottle of 42 Autosports Synchro Magic.
Our little cocktail we've used for years to help with synchro grind. Just run it with the existing transmission fluid before the fluid change for about 30 minutes and then drain while hot and enjoy happier syncros after.
Shipped Prices to US Customers Excluding North Carolina
Impreza/Legacy/Forester:
5 Speed Transmission & Rear Diff - 5L Extra-S $75 shipped
5 Speed Transmission & Rear Diff - 5L Extra-S - Plus 1L Synchro-Magic $87 shipped
5 Speed Transmission - 4L Extra-S $63 shipped
5 Speed Transmission - 4L Extra-S - Plus 1L Synchro-Magic $75 shipped
2004 - 2006 STi:
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L Motul Gear 300 LS LSD Oil $99 shipped
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L OEM Subaru LSD Oil $103 shipped
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L Motul Gear 300 LS LSD Oil - Plus 1L Synchro-Magic $111 shipped
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L OEM Subaru LSD Oil - Plus 1L Synchro-Magic $115 shipped
6 Speed Transmission - 5L Extra-S $75 shipped
6 Speed Transmission - 5L Extra-S - Plus 1L Synchro-Magic $87 shipped
2007 - Current STi:
6 Speed Transmission & Rear Diff - 6L Extra-S $87 shipped
6 Speed Transmission & Rear Diff - 6L Extra-S - Plus 1L Synchro-Magic $99 shipped
2013+ - Subaru BRZ:
5 Speed Transmission & Rear Diff - 4L Extra-S $63 shipped
5 Speed Transmission & Rear Diff - 4L Extra-S - Plus 1L Synchro-Magic $75 shipped
5 Speed Transmission - 3L Extra-S $51 shipped
5 Speed Transmission - 3L Extra-S - Plus 1L Synchro-Magic $63 shipped
All Makes:
1L Synchro-Magic $14 shipped
Shipped Prices to North Carolina Customers Including Sales Tax
5 Speed Transmission & Rear Diff - 5L Extra-S $80.44 shipped
5 Speed Transmission & Rear Diff - 5L Extra-S - Plus 1L Synchro-Magic $93.16 shipped
5 Speed Transmission - 4L Extra-S $67.57 shipped
5 Speed Transmission - 4L Extra-S - Plus 1L Synchro-Magic $79.29 shipped
2004 - 2006 STi:
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L Motul Gear 300 LS LSD Oil $106.18 shipped
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L OEM Subaru LSD Oil $1110.47 shipped
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L Motul Gear 300 LS LSD Oil - Plus 1L Synchro-Magic $118.90 shipped
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L OEM Subaru LSD Oil - Plus 1L Synchro-Magic $123.19 shipped
6 Speed Transmission - 5L Extra-S $80.44 shipped
6 Speed Transmission - 5L Extra-S - Plus 1L Synchro-Magic $93.16 shipped
2007 - Current STi:
6 Speed Transmission & Rear Diff - 6L Extra-S $93.31 shipped
6 Speed Transmission & Rear Diff - 6L Extra-S - Plus 1L Synchro-Magic $106.03 shipped
2013+ - Subaru BRZ:
5 Speed Transmission & Rear Diff - 4L Extra-S $67.57 shipped
5 Speed Transmission & Rear Diff - 4L Extra-S - Plus 1L Synchro-Magic $80.29 shipped
5 Speed Transmission - 3L Extra-S $54.70 shipped
5 Speed Transmission - 3L Extra-S - Plus 1L Synchro-Magic $67.42 shipped
All Makes:
1L Synchro-Magic $17.02 shipped
Shipped Prices to Our Canadian Customers
5 Speed Transmission & Rear Diff - 5L Extra-S $100 shipped
5 Speed Transmission & Rear Diff - 5L Extra-S - Plus 1L Synchro-Magic $112 shipped
5 Speed Transmission - 4L Extra-S $88 shipped
5 Speed Transmission - 4L Extra-S - Plus 1L Synchro-Magic $100 shipped
2004 - 2006 STi:
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L Motul Gear 300 LS LSD Oil $124 shipped
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L OEM Subaru LSD Oil $128 shipped
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L Motul Gear 300 LS LSD Oil - Plus 1L Synchro-Magic $136 shipped
6 Speed Transmission & Rear Diff - 5L Extra-S & 1L OEM Subaru LSD Oil - Plus 1L Synchro-Magic $140 shipped
6 Speed Transmission - 5L Extra-S $100 shipped
6 Speed Transmission - 5L Extra-S - Plus 1L Synchro-Magic $112 shipped
2007 - Current STi:
6 Speed Transmission & Rear Diff - 6L Extra-S $112 shipped
6 Speed Transmission & Rear Diff - 6L Extra-S - Plus 1L Synchro-Magic $124 shipped
2013+ - Subaru BRZ:
5 Speed Transmission & Rear Diff - 4L Extra-S $88 shipped
5 Speed Transmission & Rear Diff - 4L Extra-S - Plus 1L Synchro-Magic $100 shipped
5 Speed Transmission - 3L Extra-S $76 shipped
5 Speed Transmission - 3L Extra-S - Plus 1L Synchro-Magic $88 shipped
All Makes:
1L Synchro-Magic $27 shipped
Shipped prices specified above are for USPS Priority Mail, please be sure to specify a PayPal Confirmed Shipping Address when ordering. Once your payment is received your order will ship within 1-2 business days.
If you are local to us and would like to pick up your order at the shop, subtract $15 from the NC prices listed above and contact us directly.
We also keep a full range of Motul, LubroMoly, Eneos and other OE fluids in stock or available next day.
If you have any questions PM me or email us at [email protected]
Banned
Re: Cobb Accessports, Blouch, Perrin, Ividia Deatch and more! Dont Forget Your Extra-
CHECK OUR WEBSITE OR PM FOR PRICING AND SHIPPING QUOTES!
INTAKE
Intakes, Turbo Inlets, and Accessories From:
Cobb
K&N
AEM
Perrin
Grimmspeed
And Many More...
EXHAUST
Headers, Down/Up Pipes, Catbacks From:
Cobb
Invidia
Perrin
Killer B
And More ...
TURBOS
Rotated, Replacement and Turbo Rebuilds From:
42 Autosports
Perrin
Blouch
42 Autosports does Turbo Rebuilds. Contact us for information and pricing or check out our Turbo Rebuild Section by clicking here!
FUEL
Fuel Pumps and Injectors From:
Deatschwerks
Walbro
Injector Dynamics
Bosch
Aeromotive
BUILT ENGINES
Contact 42 Autosports for more information on complete engine builds.
Banned
Discussion Starter #4
We have put together this kit to replace the rubber hoses that break most often while removing your intercooler, whether to make a repair or upgrade. This kit replaces your throttle body hose as well as the 90* bend at the bottom of the 'y'. Both hoses are produced by Samco and are 100% silicone and are proven to last.
Kit is sold without clamps to save you money but are available as add on options.
We also can sell the hoses separately if needed please contact for more information.
Banned
Discussion Starter #6
Coated ACL Race Bearings - Coated by a local race team with their in house coatings for their Cup Car program. Gives you the best protection during cold starts and other low oil conditions.
Rod - $69
Mains - $117
CP Coated Pistons - We run exclusivly CP pistons then have the skirts coated in the same material as our bearings and the tops in a ceramic coating that makes for a quiet and durable forged piston.
$804 Available in
  • Standard Size: 99.5mm Bore 8.2:1
  • .25mm Oversize: 99.75mm Bore 8.2:1
  • .5mm Oversize: 100mm Bore 8.2:1
  • Standard Size: 99.5mm Bore 9.0:1
  • 25mm Oversize: 99.75mm Bore 9.0:1
1 - 20 of 26 Posts
