For Sale in Pgh PA 15203
New - Never installed/Never Used
Cobb 1050x Injectors - Part number 312150
$525 or make "reasonable" offer - Buyer pays Shipping - Paypal Goods and services Option Only OR will consider discounts for local sales
Reach me via PM with any questions and we can communicate more directly. Check this site once or twice a day.
Also you can look up my sales history on NASIOC
Thanks!
COBB Tuning 1050x Fuel Injectors
COBB Tuning 1050x fuel injectors provide increased fuel flow, while maintaining stock idle and drivability with proper tuning. Want to run E85, or need more fueling for your specific application? COBB 1050x fuel injectors are the ticket; simply add the injectors, fuel pump, tune, and you're off to the races. Corrosion-resistant internals make these injectors compatible with all known fuels, and their replaceable inlet filter extends service life.
Features include:
Thanks!
Features include:
- Nominal flow rate of 1065cc/min at 3.0 Bar (43.5 psi) using gasoline at 52 degrees C (125 degrees F)
- Maximum differential fuel pressure of 10.0 Bar (145.0 psi)
- Electrical connector—USCAR
- Works with stock fuel rail
- Matched sets with dynamic flow rate variance within 1 percent
- 14mm bottom O-ring
- Data supplied for tuning injectors with Accesstuner Software
