1 - 2 of 2 Posts
A couple scuffs but in perfect working order.
The Product: We start with a solid block of T6 6061 aluminum and have it CNC machined to our specs. We designed our brace to be extra beefy to provide maximum rigidity while also being lightweight. We then use a mil-spec type-3 hard anodize to coat the brace, this prevents corrosion and also has the benefit of hardening the surface as well. We provide new mounting hardware with the brace, all Grade 8/Metric 10.9.
These braces are also designed and manufactured here in the U.S.A. They are super high quality and a lot of time and care was put into designing, manufacturing and testing these braces before we decided to bring these to market.
So who is this good for? Well, any 2008-2014 WRX or STI owner would benefit from this. If you already have the dreaded clutch pedal squeak this brace can reduce or even eliminate that noise and extra pedal slop. If your car doesn’t yet squeak, you can use this brace to prevent those welds from being stressed and potentially breaking.
This also works great for those of you who have upgraded your clutch and put more force into the pedal system. Adding in the extra rigidity of this brace agaisnt the firewall will benefit in better pedal feel, and clutch engagement.
Real Life Feedback: We sent out a brace to be independently tested by another well known shop, they post on NASIOC quite often and are very respected here. They installed it on a customers’ car and let the customer use it for a few weeks. This was their customers’ review after that time:
“After the clutch brace was installed I noticed an immediate difference in the feel of the clutch. Under normal driving the clutch play feels smoother and more sturdy. Under spirited driving the clutch feels like it’s attached to a brick wall and has no give in the firewall.
After driving the car for several thousand miles I have become accustomed to the clutch. It feels like a solid unit that should been a stock part included from production.”
$165 shipped, you pay PayPal fees.
PM me for pics
1 - 2 of 2 Posts
