What you are describing is "limp mode". A few on and off cycles of the ignition usually clears it, once the problem is corrected. Did you work on the car recently?
First off thank you for respondingWhat you are describing is "limp mode". A few on and off cycles of the ignition usually clears it, once the problem is corrected. Did you work on the car recently?
