1 - 3 of 3 Posts
Re: lmbao
i was just browsing the links and found teagues auto has carbotech brake pads available. i am going to call 1st thing in the morning, we'll see if they are in stock. pads for front and rear are about 250.00-350.00 depending on compounds wanted.
sorry if this is a repost, i couldn't find any others
4mla1fn- thanks, in that post he used panther + pads (middle grade)
there is one step below that offers better breaking with less dust. that pad is called bobcat compound good heat range is 35 - 900. (for street and tight autox events)
refering to the other post: i personaly do not agree with changing back and forth between pads without at least putting rotors on a brake lathe and using medium emery cloth lightly on the surface. by not doing this you will mix the two compounds and glaze one or the other. IMO.
ted
1 - 3 of 3 Posts
