Car dying upon idle mystery
1483 Views 16 Replies 5 Participants Last post by  JDMSTi7
Issue: Upon coming to a stop in neutral or once the car has already come to a complete stop the motor will die out. However, the issue is that it is so random and sporadic I am never able to recreate the situation. Sometimes the dying out will happen every stop, sometimes once or twice, sometimes it will never die out? Idle sometimes fluctuates and sometimes stays right below 1k.
I will list my modifications below.
Situation been ongoing since April 2013 with no resolution yet.
Modifications: (all modifications have little over 4k miles purchased brand new)
P&L shortblock
Blouch 18g Turbo
Invidia N1 street turbo back
P&L motorsports up pipe
Perrin turbo inlet
Cobb short ram intake
Walbro fuel pump
Mishimoto oil catch can
Mishimoto aluminum radiator
Stock injectors and top mount (both have 64kmiles on them)
Car was tuned at 16psi in April Open source I do Not have an acessport.
Does anyone have any idea what to check or what to do?
Can the fuel injectors or rail be causing this problem?
Thank you in advance
1 - 17 of 17 Posts
check your fuel pressure.
I have a 18g as well, and I had this issue awhile back when I had injector problems. So it might be a fueling problem not but necessarily injectors. I got new injectors and plugs with a new tune and the problem went away.
Also come to think of it, it might not be a fueling issue but rather a vaccuum leak as well.
Thanks I will have to take a look into it
Thanks I will have to take a look into it:tup:
What injectors do you have now? still side feeds or did you covert to top feed? And I checked for leaks as did a shop and no vaccuum leaks anywhere I am assuming it has to be fuel related.
I had a used set of PE 850 side feed injectors and I bought a brand new set of the same setup. My impressions were that it was the tune because the one injector was sticky so that injector got a little more fuel then the others, that combined with a leaky bpv I felt caused the issue.
With me in the car it was once in a while. But with gf in the car it did it at every stop but that day was every hot outside. I think it may have been the added load on the car.
I had similar issue (not on Subaru) and it was a mass air flow sensor.
Thank You i have looked into this as well cleaned mine and still had the issue swapped for a while with a friends and still motor has still been dying
This just came across my mind! Check O2 sensor!
Checked o2 sensor its brand new
Did anyone ever have an issue with coolant temp sensor or camshaft sensor possibly ?
camshaft sensor usually gives CEL, but couldn't hurt to check it
your not alone on this one, my car has done it to me twice, whats interesting is that on cold starts i smell fuel on the driver side of the motor, i don't know if its related of not. also my car has a built block and bigger turbo too.
hmm how frequently has it happened to you? mine is happening almost all the time i drive
its not that frequent its only happened twice. but its strange the car just shuts off, mainly when approaching a turn popping it into neutral and into a lower gear dose it for me. that transition the car just dies. another one was when coming up to a toll agian neutral into a lower gear the car just shut off again. the car is at normal afr readings, and appears to have no boost / vacuum leaks too.
its on a built short block with an fp green, and it has 850 deatschwerk injectors, and a walbro fp.
Hmm I am bringing it to P&L motorsports and see what they say about it..
1 - 17 of 17 Posts
