1 - 20 of 26 Posts
All parts off an 08 sti unless noted. Located in ocean county nj. I just want this stuff gone so dont be shy. Also open to trades. The only thing i will absolutely not ship is the catback
Catback 50
Intake with snorkel, silencer, bracket, and filter 50
Stock ebcs with hoses, boost pill, and reducer that goes on turbo inlet 30
shifter lever 20
antenna 5
pitch stop 30
Front sway bar with bushings 50
Front endlinks 25
Fuel pump with filter 50
Complete secondary air injection system except one valve with the pressure sensor ???
Turbo inlet 20
Wastegate actuator 10
Oil pickup with windage tray 50
One used piston 30
3 used rods 10 each or 25 for the set
another full set of good sti rods supposedly shot peened and balanced 50
brackets that go over the injectors 10 for both
Pcv y-pipe that bolts onto intercooler 5
pcv cross pipe under the intake mani that connects the crankcase breather to head breathers 5
Stock fpr with balance hose and dampeners 30
Stock bpv without the elbow 30
Miscellaneous gaskets pm me if you need one
Invidia n1 silencer fits any 4 inch tip 10
07 sti under engine splash guard 10
If i can think of anything else ill update. Like i said i want these gone so no unreasonable offer will be denied
Discussion Starter #13
Just the lever with the bushing or whatever where the pivot bolt goes thru. no knob, normal wear n tear for 50k miles
1 - 20 of 26 Posts
