1 - 20 of 42 Posts
Hey guys thought I would do a quick build thread for my urban grey Hawkeye. Started out with basic bolt on's vf34, PW top mount, 3" Turbo XS and a flash tune which was super fun and managed a [email protected] The car stayed that way till it's journey of 2 engine builds as below...enjoy!
BUILD 1
Car: 2007 WRX
Tuner: Justin @ JW Automotive
Dyno Info: Mainline Dyno
Transmission: 6 Speed Long Ratio
Gear: 4rd
Peak HP: Dyno 502whp
Target Boost: 27 psi tapering to 25
Fuel: Pump E85
Engine:
EJ257 closed deck 14mm. head studs
99.75 CP pistons
Manley H Tuff rods with ARP bolts
ACL race bearings
BC 272 cams
Ported heads, 1mm oversize supertech valves, double valve springs
Killer B pickup and baffle
Plazmaman custom 1000hp water to air intercooler
3bar MAP Sensor
Grimmspeed ECBS
TGV's deleted, 3mm phenolic spacers
Cosworth air pump delete kit
Roger Clarke rotated kit up /down pipe, Garrett Gtx3076r .82 hot side Tial 44mm EWG @ 1 bar springs, EWG Rerouted to DP
ID1300cc injectors
Walbro 460 fuel pump Hard Wired in tank, Aftermarket Industries Surge tank with 1000hp Holley dominator pump, Aeromotive fuel rail kit w/ FAST regulator
Jim Berry Race Clutch
IMG 2793 zpsmcwwpzwu
59113
Discussion Starter #8
Straight back into its home. Now time to see how the rotated kit fit's and how do build a custom water to air intercooler setup...
59119
Discussion Starter #9
Bolting up the rotated kit...everything went to gather except v bands for the gate didn't match up so off to fab shop. Same it was already ceramic coated :(
59120
59121
Discussion Starter #10
More progress with fuel Ines and Aeromotive rails and Killer B high fill..
59122
Discussion Starter #11
Making rough mock ups for the water to air core to see if it would fit under the bonnet..
59123
Discussion Starter #12
Plazmaman were amazing to deal with delivering a beautiful 1000hp Por Series intercooler with custom end tanks, custom heat exchanger and reservoir...
59124
59125
Discussion Starter #13
More progress with inlet manifold and intercooler core roughly mounted up with all silicon couplers..
59126
Discussion Starter #14
First incarnation of the install. Wasn't happy with the BOV record but the police and transport love dishing the fines here so it is what it is...
59127
Discussion Starter #16
This was the first tune after flex fuel was set up...green is 98 (US 93) and red is pump E85
59131
Awesome!
Very similar to what I would like in my next build - though there is a good chance I will end-up in a VA body.
Interesting parts we don't see :)
Curious, what is your long ratio (from) ?
Discussion Starter #18
Awesome!
Cheers! I have tried to be a bit different with my build. Long ratio box is from a 2012 still 3.9 final drive.
Discussion Starter #19
Car stayed this way for 2 years/10,00km and was awesome to drive...until it started pushing coolant :cry: We had doubts about head gasket/head surface integrity from the first time we put coolant in it and it leaked between head and head gasket.Once the heads were off we could see the machining was so poor it had left an imprinted pattern on the gasket itself. At this point we decided to pull the whole motor down and check everything...wasn't pretty so it was decided to start again with a new block and full rebuild of the heads. I was devastated :( Not interested in talking about who built it as that's in the past and it benefits no one.
59141
Discussion Starter #20 (Edited)
BUILD 2
Dyno Info: Dynapack Hub
Gear: 4rd
Peak HP: Dyno 592whp
Target Boost: 28 psi
Fuel: Pump E85
Engine
EJ257 closed deck
99.75 Wiseco AP pistons
Argo I Beam rods with ARP bolts
ACL race bearings
Ported heads, new valve seats
Billet 288 custom cams
1mm oversize supertech valves (inconel ex), Kelford beehive springs
ARP 1/2 inch head studs
Killer B sump, pickup and baffle,
Cosworth inlet mainfold
Tial QR BOV
5bar MAP Sensor
Grimmspeed ECBS
Killer B overflow/washer bottle
Mishimoto x line radiator
25 row oil cooler
Turbo
Xona Rotor 7164 1.03 hot side (.86 initially see following story)
Fab Lab rotated kit up / 3.5" down pipe, Tial 44mm EWG @ 1 bar springs, EWG Rerouted to DP
Turbosmart turbo oil pressure control
Fuel System
ID1700cc injectors, Walbro 460 fuel pump Hard Wired in tank, Aftermarket Industries Surge tank with 1000hp Holley dominator pump
Sensors
Oil pressure/temp
Fuel pressure
Intake temp
CAN wideband
Emap
59142
1 - 20 of 42 Posts
