Never changed pads on a Brembo four piston setup before. Someone asked me how to you push the pistons back in the caliper if there are two on each side? Figured I would ask. Do you have to do that when changing pads or are these piston setups not designed that way like a traditional brake setup where you would use a c-clamp to push the pistons back in?
