Cool Software for the Site
First, I am not yelling, using BOLD to get your attention
READ the MANUAL - specailly the WARRANTY book which is easy to read. If you follow the factory requirements you are covered by the warranty, which is VERY IMPORTANT.
Just use regular oil, the engine is designed to allow regular oil to flow and cool properly. The heads have specially designed channels to keep the oil flowing properly even in high speed conditions. Change the oil every 3-months/3,750-miles and follow the maintenance guidelines. A small investment now is better than major costs later (ie do not cut corners).
As far as break in do NOT GO OVER 4,000 RPM for the first 1,000 miles. You can hit 4,000 rpm, just back off and do NOT SUSTAIN it. After 1,000 miles then do any type of phased in method you want, just do NOT do this before 1,000 miles.
Set the REV LIMITER for 3,800 rpm, including the audible, and you are covered. Again, do not cut corners.
