1 - 18 of 18 Posts
My 2016 STI (28k miles) has been making some squeals while braking, so we all know what that means. :cool:
Running short on funds, but am trying to determine if brakesplus is ok to use for a service provider, as they do carry Centric Rotors and Centric Pads.
I asked for a quote on semi-metallic pads and blanks, as they determined they are not able to refinish the rotors safely. He said the pads are all going metal to metal on the rotors.
Using their own in-shop parts, they quoted me $855 for all 4 corners replacing pads and rotors, which includes a brake flush and alignment.
This link shows what they are installing, but I am not sure if this is "just as good" as stock is on my STI. I'd at least like to get as close to stock as possible, without cutting corners.
https://www.tirerack.com/brakes/brakes.jsp?make=Centric&model=Preferred+Axle+Pack&autoMake=Subaru&autoModel=WRX+STi&autoYear=2016&autoModClar=
On the other hand, if I bring my own parts, ordered from CygnusPerformance or other vendors, they (Brakes Plus) offer no warranty on them, but I have more flexibility in knowing what is going on my car.
I had the Cygnus brake package picked out with free shipping for the DBA T2 Street Series Slotted rotors with Hawk HPS pads, bundled at a really fair price on their site.
I'd have to pay $120 per hour labor with no warranty on the parts, so about 200-240 figuring on 1 1/2 to 2 hours of labor based on the technician's estimate. Factor in the alignment and brake flush it's about the same price, at $860 with parts and labor.
My question is, does this sound like a good deal, either way? Has anyone been in this situation before? I am not able to install myself, or I would definitely do it.
Thank you for your time. My sincere apologies if this is too similar of a post for the forum, I could not find specifics like this situation, I just want to avoid being ripped off or have sub-stock components placed on my STI (BP assured me that they are fine, but I don't know much about comparing brake parts).
Have you actually verified the brakes need replaced, or are they just making noise?
I wouldn't have Brakes Plus do any work on the car. I would just buy quality rotors and some StopTech Sport pads and do the work yourself.
I can feel grooves in the rotors with my fingernail, there is a nice visible grooved line on the rear brakes as well.
I am not able to do the work myself, or I would. I do not have the tools or the technical skillset. I am the guy who popped the driver's side cv-joint off while trying to remove a simple strut in a 2004 Neon, I am not about to wreck my car's brake system ;)
I'd like to learn how, eventually, but work and kid's activities need me to get this done in a week's time.
I have a local trusted mechanic, but his labor rate adds an additional 300 dollars to this, and no brake flush or alignment.
That description doesn't make them bad. You should see my rotors after a set of track pads driven on the street.
Brakes are pretty simple and popping out an axle while working in the area isn't a big deal.
You get the parts, bring the car over to my place, I'll teach you how to do brakes. However, I'm not convinced they are dead yet.
rallysportdirect.com had a sale last year that enabled me to buy EBC ultimax rotors and pads for all 4 corners for under $300 shipped. I finally got around to doing the swap a few weeks ago. Super easy stuff (aside from one rusty caliper bolt that took a lot of force to break loose). Definitely can be intimidating the first time, just because it's your brake system, but the Brembo system is so simple you can't screw it up.
do you have autozone near you? their rotors are cheap and they can also get brembo blanks for great prices too! i got all my parts for ~350 pads and rotors on all 4, and did it myself
Edited (Didn't read full post)
A full brake kit (Front and Rear rotors and pads) from a great brand should run you around $550. A kit from Oreilly's or Auto Zone should be around $350, I believe. Personally, I wouldn't use a kit from a parts store on my STi. I also would never let Brakes Plus work on my car either, as they tend to be operated by kids. But I get you trying to save a buck or two.
If they're throwing in a brake flush and an alignment on top, that's a fair deal.
Here's a link from Rallysport. But if you shop around, say at ImportImageRacing or Aristocrat Motorsports, you can probably find them much cheaper.
Brake Upgrade Kits
Brake Upgrade Kits
And remember that you will possibly face stripped threads on those Brembos, which is a notorious problem. Not likely, but it's a possibility. You just have to get lucky that they don't strip out.
Do this instead. Brakes on these cars are so easy.
Also... forget slotted rotors. They look cool... but you definitely don't need them. Especially not just street driving. Especially if you're on a budget. HPS pads are usually known to be less aggressive than the stock Brembos... go for something like a Stoptech Street pad.
Also... if you haven't changed pads on the car before, I'd be very surprised if your front and rear pads were both worn out. I go through front pads about 2x as fast as rears.
heard anything about project mu street pads?
whats wrong with autostore parts? centric is a big name brand iirc stoptech is a part of them, autozone gets brembos directly from the manufacturer, their own rotors I agree aren't the best but work well, I have had mine for nearly year and a half and nothing noticeably bad...I was really short on cash or would have spent the extra 40 per rotor to get brembos...I do go with the duralast pads as I do like free pads whenever I need them...personally do the GT currently and like them...nothing to use on the track for sure but they work for my driving environment/style
I dont know what brake plus is but from the sounds of it, it sounds like a crap pep boys/just out of tech school shop. If that is in fact what it is, i would highly recommend you not get anything done there let alone even go there. I get that you're trying to save the $$ but this is your car and im guessing your daily. I wouldnt go for the auto part store stuff, do you really want to cheap out on brakes on your sti? My recommendation would be to get the good stuff from cygnus performance and have your trusted local mechanic do the work. Good, skilled, knowledgeable labor is hard to come by and is charged accordingly.
^ This is very generous and the way OP should go. OP, you learn to do this once and you'll never have to fret about paying for this job again. I'd suggest grabbing some gloves for you and your host plus brake cleaner and some copper anti-seize as well.
Brapp: Due to torque vectoring VAs and other modern cars commonly go through rear pads before front!
and like a whole case of beer, or a generous donation to his garage or just help with soemthing he needs help with . . . . !
Discussion Starter #16
Thank you so much, everyone.
yamahaSHO, may I please take a rain check on the offer? I will swap out the 'meh' pads later in the fall.
I am extremely appreciative, I know how valuable time is, please understand.
Long story short, we had a family medical emergency Friday afternoon, and as a result, had to change all 7 day plans asap.
Had USAFA events all day Saturday with my son, his "Doolie Day Out" with a few other cadets.
Needed the car done by today, so local mechanic is taking the job to be done today.
Situation-forced into ordering Centric High Carbon blanks, and and Centric Composite (Semi-Metallic) Pads through local trusted mechanic for quick-turn around. Local (highly trusted) mechanic also said my pads were as thin as paper and the rotoros were not re-useable, machining them would probably crack them he said. Right rear had deep gouge from the pad being gone completely on one portion of that pad, almost 2 millimeters. He said the rotors are being scratched by the remaining 3 pads, and they are past the 'end of life' on the pads. Didn't know sti's ate brakes so fast. I don't track the car, or do anything crazy in it.
Still reeling from Friday's medical emergency though, sorry for the brevity. Thanks again, everyone.
you must brake pretty hard lol! My 2017 sti with 30 k miles (daily driver) apparently has ~ 80% brake pad left in front and 70 in back
1 - 18 of 18 Posts
