1 - 7 of 7 Posts
Looking to invest in a set of brake pads for a 13 wrx sedan. What are some good pads for 90% daily, 10% autocrossing?
Hawk's Street Race pads and Endless MX72 pads are probably going to be your best bet if you need a pad that can handle autoX and not be loud on the street. Both make a little bit of noise on the first couple stops but then quiet down after that but give you almost track pad like feel and bite.
Sent from my VTR-L09 using Tapatalk
given how super easy it is to change brake pads on brembo calipers it really makes a lot of sense to just switch to a dedicated track pad the day before or day of a trip to the track, and then switch back to the stock pads for daily driving. Both sets of pads will last longer that way as well.
You don't need a dedicated set of pads for autocross. I've been autocrossing a long time and I really like the Project Mu B force pads. They have great initial bite and modulation, and hardly dust at all. Endless are considered the best, but they are spendy. I'm not a fan of Hawk's performance street pads. They dust way too much for my taste. Check out Cygnus Performance | Late Model Import Parts STi, WRX, BRZ. I've bought from there many times and their prices are about the best I've found for brake pads. KNS Brakes are good too.
oh, this is a WRX, did you do a brembo swap? If not then maybe not worth the hassle to run 2 different sets of pads....if not maybe look into installing a brembo set up, it literally takes 5-10 minutes per wheel to remove and install a set of pads.
lurking Subaru whore
I can personally vouch for the Endless MX72 brake pads.
Though, they're more of a daily-driver and light-track hybrid compound. If anything, the MX72 is overkill for autocross, but perfect for the spirited driver who takes on short circuits and/or the touge.
For a brake pad that can safely hit 1292 degrees Fahrenheit, they are exceptionally quiet.
tl;dr Endless MX72 brake pads are a unicorn track-capable street pad :bow:
1 - 7 of 7 Posts
