1 - 12 of 12 Posts
Hi ya'll
When do you guys acutally do the 1st brake flush? I know the service book says 30k, was wondering if it would be OK if say I chose to do it around 35k.. does 5k or 6 month delay make that much of a difference?
Cali isn't that humid so I wouldn't think that's a major factor in doing it that early ...
thank yu
The exact mileage is not critic at all.
Some cars never get one.
honestly just wanted to do with it when I have to replace my brake pads, but I think my pads will last til ~ 60k lol ...
Honestly? I think thats when most people (DD) do it - unless they just do whatever the dealer tells em. Track use is a different story.
Discussion Starter #6
Im definitely going to be changing out my trans fluid though @ 30k.. I feel like ill get more buttery shifts if I swap out OEM fluid to motul :)
probably will just hold out on brake flush til pad replacement then since I don't track at all and only use it as DD
Probably just fine to wait if it's a DD only. Though it's not like it's an expensive or involved procedure.
It is ok to wait a little longer than recommended. I would still say to do the brake flush though. Especially if you are someone who drives the car hard often and heats up those brakes.
i go by color and time. typically flush every two years... or if its like super dark.
got a lexus hybrid tho, color hasnt changed at all... but i'm lazy to get it flushed at the dealership cuz i dont think i want to DIY those things.
Every 2 years is what i usually go with regardless of what the manual says. Keep in mind brake fluid is hygroscopic.
I have worked in European dealerships for the last 25 years and we always recommended 2 years. Most of the manufacturers list 2 years in the manual also.
1 - 12 of 12 Posts
