1 - 9 of 9 Posts
Hoping/thinking its not a very big deal, but after reversing from a parking spot I pulled forward into, the brakes will click/squeak, just once. When going forward to brake again, the brakes make the same noise again, but again only once.
I have an idea of what it might be, but what is your opinion? Is this a common problem with stock brakes?
Thanks in advance,
Chris
Sotck everything. Been doing it since I got the car 3000 miles ago.
Mine clicks also. I think it is the pads shifting on the pins when the car changes directions.
I just replaced my pads this past Sunday and now I am hearing the exact same thing you are! I asked this same question on the NASIOC forum and no one knew what it was.
Mine does too. Didn't on stock rotors, does on Carbotech rotors. It's just the pads hitting the pins. Nothing to worry about.
its normal
my car does the same CLICK!!! I have stock brake system.....is good to read that is normal....:D
:tup:
1 - 9 of 9 Posts
