1 - 12 of 12 Posts
Does anyone know the bleed order for the 2018 STI? If not can you share the 15+ bleed order. If I can’t get 18 specific I’ll assume it’s the same as 15-17 and follow that order.
Thanks!
Each brake caliper has 2 bleeder valves, so you have to make sure you bleed both valves (one at a time) before you move on to the next caliper, the order would be RR, LR, RF, LF
rule is furthest to closest
IMO you what to bleed the wheel furthest from the ABS module first not the master cylinder, then move closer to it. So if the ABS is in the RF of the engine bay then the order would be LR,RR,LF,RF. Also you going to need to cycle the ABS to get any old fluid. I did this on mine when switching to Dot 4.
Discussion Starter #8
I understand this is a really good rule of thumb, but I know that for some reason our brakes have a weird order. I’m sure I’m not gonna die in a firey car wreck if I don’t follow the particular order but I figure there’s a reason they deviate from the norm.
Also you may want to try getting the ABS to cycle after bleeding. Sometimes there are small bubbles trapped in it.
What do you mean by this?
All the brake lines feed into the ABS module. The dealership has a way to manually cycle the ABS system (that feeling you get in the pedal when the ABS activates). As we don't have a way to do this you might want to look into braking really hard on a slick service to get the ABS to trigger so that any air left in the module is pushed out. It can result in a better brake pedal feel if you bleed it again after triggering the ABS.
Although, I personally don't think it make a serious difference and I've been taught to always bleed/flush starting furthest from the M/C, moving towards the M/C, the Subaru Service manual has a different sequence. I'm only posting in here, in case someone else comes along and they want the "Subaru" recommended sequence, which is what the OP was asking for, but received bad information.
Subaru Service manual for 2018 recommends the following sequence, RF > LF > LR > RR always starting with the inboard bleeder 1st. In case someone reading here doesn't know, our Brembo Calipers have 2 bleeders each.
1 - 12 of 12 Posts
