1 - 8 of 8 Posts
Which one actually has more cranking power? I'm having problems with my Braille (it won't hold a charge). So I'm thinking about getting a PC680 to put in while I send my Braille back for them to look at. If they replace it under warrantee, I'll probably just sell it. BUT, which battery is actually better during cold starts and which will hold a charge for longer? And is the PC680MJT basically just a PC680T with a metal jacket for extra protection?
Which Braille battery are you talking about? There are two of them.
Although you've seen mine and others' comments elsewhere on the board, but I think it has less to do with CCA and more to do with internals.
I'm sure Braille is quality, but I've seen a ton of them "act up" compared to the Odysseys.
BTW...I've had my PC680MJT for nearly a year with it sitting for about a month and no problems.
pwn n00bs
do you think something is running in your car causing it to go dead if it can't hold a charge? maybe it needs a better connection too.
1 - 8 of 8 Posts
