1 - 5 of 5 Posts
For the next two weeks, we are offering FREE SHIPPING ($10 off) on this item. Just enter the discount code "KOI Special" when checking out.
Stock battery weight=32 pounds
Braille Battery weight=11.5 pounds with hardware
TOTAL WEIGHT SAVINGS OFF THE NOSE OF THE VEHICLE=20+ pounds!
This works in all sorts of weather conditions.
The Braille battery has been referred to by many as an 'insanely small battery' tipping the scales at a mere 11.5 lbs. Comes with all necessary installation components including automotive posts and nylon spacers for a quick and easy installation in the STi. Click here for the comparisions between this battery and other lightweight batteries on the market: http://www.imprezawrxsti.com/postnuke/modules/PNphpBB2/files/comparison_sheet.pdf
Technological features:
Factory Sealed Valve Regulated Design Eliminates damage from Acid Spills
Environmentally SafeHigh Density Oxide. This enables Braille to produce a "High-Cycling" lightweight battery
Heat Sealed Top Battery Cover Eliminates Electrolyte leakage
Absorbed Demineralized Electrolyte Improves service life and off-season storage
Heavy Duty Automotive PostsResist Damage from Vibration of Heavy Use
Easy installation
Calcium Full Frame Power Path Grids Provide Highest Cranking Amp to Weight Ratio
Lowest Self-Discharge Rate
The Specs:
Voltage: 12
AH: 15
PCA: 700 Pulse Cranking Amps
Length: 5.8”
Width: 3.3”
Height: 5.9
Weight: 11.5 lb or 5.2kg
Use: Road Racing, Drag Racing, Rally Racing, Auto- Cross and Daily Use.
1 - 5 of 5 Posts
