A Little About Me
I am a Porsche guy at heart, with the family's 911s soon to be a project car. I am a firefighter/paramedic by trade. I have a wonderful wife (Cary) who puts up with my insanity and a daughter, Elliot Catherine, born 12/19/10.
My Vehicles
1971 911s (Now in PA, in need of TLC)
1988 Chevrolet K5 Blazer (retired)
1998 Dodge 1500 P/U (leased, returned with a transmission about to die)
2000 Toyota Tacoma (retired)
2002 Nissan Maxima (traded, why I drive a Subaru, see my sig or linky)
2006 Toyota Tundra (tow vehicle and daily-driver)
2007 Subaru Impreza WRX STi (current)
2008 Econo-Trailer open-deck trailer
Projects
GD Brake Cooling
Airbag Light Fix
How-To: Vibrant Performance Washer Fluid Bottle Install
Heat Cycling R-Compound Tires
Seat and Mount Compatibility Guide
How-To: Small Battery Mount
Auto IC Mod Post #48
Track Time
I am currently a licensed NASA Time Trialer, competing in TTB. I am also a NASA certified Instructor (Level 1).
Engine/Intake/Exhaust
I want to give a HUGE THANK YOU to IAG Performance, Ken at WRXBrakes, and Clint/Tony from TiC. You guys have provided excellent service, advice, and parts for this project! Also a big THANK YOU to Justin Matthews who helped me refine this build.
I also want to give a big thanks to Vibrant Performance who has graciously provided me with a washer-fluid bottle to free-up some space for my brake duct install.
My Vehicles
Projects
GD Brake Cooling
Airbag Light Fix
Track Time
- October 13-14, 2007: NASA HPDE1 @ Summit Point, WV -- Pics | Pics
- October 11-12, 2008: NASA HPDE1 @ Summit Point, WV
- April 25-26, 2009: NASA HPDE1 @ Summit Point, WV
- April 17-18, 2010: NASA HPDE2 @ Summit Point, WV
- June 19-20, 2010: NASA HPDE2 @ Summit Point, WV
- August 21-22, 2010: NASA HPDE3 @ Summit Point, WV
- November 6-7, 2010: NASA HPDE3 @ Summit Point, WV
- April 8-9, 2011: NASA HPDE3 @ Summit Point, WV
- June 18-19, 2011: NASA HPDE3 @ Summit Point, WV
- June 19, 2011: NASA TTB 3rd in both races @ Summit Point, WV
- October 6-7: NASA Instructor 1 Clinic @ VIR, VA
- November 5-6: NASA TTB + Instructing @ Summit Point, WV
- April 28-29, 2012: NASA TTB + Instructing First Place Trophy@ Summit Point, WV
- July 16-17, 2012: NASA TTB + Instructing @ Summit Point, WV
- November 3-4, 2012: NASA TTB + Instructing 2nd place Trophy@ Summit Point, WV
- Cobb SRI + Box, DEI-gold taped
- Auto IC Spray Mod @ 9psi
- Cobb Radiator Shroud
- Borla XR1 Cat-Back
- Motul 5w-40
- GroupN Motor Mounts
- Kartboy Pitch Stop Mount
- KillerB PU Tube
- KillerB Oil Baffle
- IAG Air Pump Delete
- Manley Pistons (forged)
- ACL Race Bearings (rod and main)
- ARP Hardware
- 11mm Oil Pump
- Gates Timing Belt
- Invidia DP + Wrap
- Perrin Inlet Hose
- 93 Octane Tune but IAG/Jorge: 284HP, 232TQ
- COBB AP Stage 1-93 octane
- Kartboy Short Shifter
- Kartboy Front Shifter Stay Bushings
- Kartboy Rear Shifter Stay Bushing
- Kartboy Rear Outrigger Bushings
- TiC Shifter Linkage Bushings
- TiC Pivot Bushings
- TiC Tranny Crossmember Bushings
- Whiteline Subframe Lock Bolts
- WC Lathewerks Weighted Knob
- GTSpec Rear Differential Mount
- GroupN Transmission Mount
- Motul Gear300 75w-90 for Diffs and Transmission
- TiC Spec AST's - Length: 8/9, Rate: 8K/6K
- Vorshlag Camber Plates (Rear)
- GTWorx Camber Plates (Front)
- Kartboy Front Endlinks
- Kartboy Rear Endlinks
- Whiteline 24-26mm Front Bar
- Whiteline 22-24mm Rear Bar
- Whiteline Caster Bushings (RACE)
- TiC Lateral Link Bushings
- TiC Forward Trailing Arm Bushings
- TiC Rear Trailing Arm Bushings
- DBA5000 Slotted Front Rotors
- DBA 4K Slotted Rear Rotors
- TechnaFit SS Brake Lines
- Motul 600
- Ferrodo 2500 Pads (Street)
- Hawk DTC 70 Front Pads
- Hawk DTC 60 Rear Pads
- TiC Master Cylinder Brace
- Roo Ducts (ABS)
- Quantum Brake Ducts (unused)
- Lowes Racing Duct Inlets
- 500* Neoprene hose
- TiC Ti Brake Shims
- Bridestone RE01R 245/40-17 (Summer/Track-Wet)
- Bridgestone Blizzak LM25 225/40-17 (Winter)
- ASA Wheels (Winter)
- Stock BBS Wheels (With track-tar mod)
- TRM 17x8.5 (Track Wheels)
- Toyo R888 245/40-17 (Track-Dry)
- Muteki SR48 Lugs
- ARP Extended Studs (pending)
- GForce 6-Point Cam-Lock Harnesses
- Autopower 4-point Roll Bar
- Eclipse 5341 Single DIN Headunit
- Forester DIN Pocket (hacked to hold DEFI Link)
- DEFI BF Imperial: Boost, Oil Pressue, EGT, Link
- Perrin Oil Pressure Sensor Relocation Kit
- 3 gauge Clock Pod
- 3M 20% Tint
- Airbag Fix
- Sparco Evo 2+ Seats
- Buddy Club Driver's side rail; Bride (for now) Passenger side rail
- Contour ROAM Camera + Bar mount
- DisplayIT Lap Timer + Custom plate and switch for Timer and Transponder power
- V-Limited Replica Front Lip - Painted Flat Black (removed for TTB)
- Grill Craft Black Mesh upper and lower inserts
- Rally Sport Urethane Flaps (removed for track)
- Pending
