101 - 120 of 2880 Posts
Re: Looking at Meth Kits.... Need to break the stock turbo record
If you want to seriously break the current record (i dont know if its downsti or juanmedina anymore), you should add as little weight as possible and take off as much as you can. This is just to ensure that you DO actually beat it and not waste your money.
I say this because it kind of seems like you want some of the bling to go with your street-cred for being one of the fastest stock turbo cars.
a spec-C 12 liter tank is heavier than a little 1 gallon tank (more plastic). Not by much, but weight adds up if you keep adding it.
You want the lightest wheels and brake rotors you can get your hands on, and suspension thats set up in a way that will launch you out of that hole with lots of grip.
Since you're aiming for the stock TURBO record and nothing else, might i suggest the following:
1. drag radials
2. anorexic sti style interior (gutted and reassembled)
3. EWG and cutout on the downpipe as close as you can to the turbo
4. as much weight shaved as you can.
You're trying to break a record. Might as well set one that can be kept for a LONG time.
Discussion Starter #102
dr's i have.
the interior im going to working on in the summer, see what i can get rid of.
EWg is on it's way
Weight i will take care of when i start heading to the track.
Spec-C is the best approach in my opinion honestly. Hell, you really want to penny pinch the weight area, use the I/C spray tank in the back of the trunk for your meth.....my buddy is doing that with no problems other than the tank being small for daily use yah know?
Discussion Starter #104
Thats what i'm saying. I'd much rather that spec c tank where i dont have to refill it ever 4 hours.
^Then there is your own answer :lol:!
on the stock turbo... what would be a good figure to look at as far as boost?
right now i'm at 22psi. With meth what should i be looking at?
About the same. Im tuned at 21-22 PSI.
Honestly the 1.5 gal trunk mount lasts me several weeks. If you want bigger there are options that cost much less than the spec C tank.
Also the way David (coolingmist) and I set up the tank you can have it less thean 25% full, drive the hell out of it, and it will still only pick up alcohol.
Re: Looking at Meth Kits.. Looking to break the stock turbo record
I just like the mounting option for the Spec-C its a nice and clean install, doesn't move around, and doesn't stick in the middle of your trunk or to one side and throw the weight off of your car. Just my .02 cents:)!
Wirelessly posted
True. I wonder how hard it is to fill the spec c tank. I guess I should look at the install pics. Regardless I think my trunkmount tank looks pretty sweet. LOL
dr's i have.
EWg is on it's way
it's very good to know you're serious about this in terms of planning and giving yourself enough time to get the work done. I'm a big believer in the brakeman rotors and calipers to shed lots of weight as well.
I really wish you the best and I hope you attain your goals. I was really impressed with timeatk (nasioc) and his tune with a cutout very close to the turbo. I'm not sure if he ever took his car to the track.
Discussion Starter #115
thanks sir!!!!
Looking at a lot of rim selections today.
what is the lightest rim. So far i've seen the OZ allegrita to be the lightest.....
thanks sir!!!!
How much do they weigh?
