I've searched hi and low and cannot find any useful information.
I am troubleshooting a boost problem and would like to know the boost I should be seeing on my boost gauge when i turn my Greddy Profec B Spec II boost controller OFF.
1> I thought I would be seeing the factory spring pressure which I think is around 7-8psi per all the threads I have read. Instead, I see 14.5psi. Is this correct?
2> If i bypass the boost control solenoid and plug the hose from the turbo compressor housing directly to the wastegate actuator nipple, I should see the factory spring boost pressure correct?
Thanks for all the help.
