1 - 6 of 6 Posts
Got the ap and base mapped the stage 1 93oct....peak boost values were as follows in each gear:
1st 13.5
2nd 14.0
3rd 14.5
4th 16.1
Look normal??? I realtimed the 91oct HWG versoin just for the heck of it and got close to the same numbers.....?
And on the AP when you select show current map will it always display the base map? I switched to the 91 realtime map and it sent but then when I chose show current map it displayed my base map...
The numbers look normal. If your getting 16.1 PSI in fourth, you might want to check what 5th/6th gear get. If it starts creeping too high this is too much, and the HWG map is not the best solution. Stage 2 is set for 17.5 psi +-.05, so you will want to stay below that on stage 1.
1 - 6 of 6 Posts
