10 sti
Thanks for clearing that up, We started out with talking about water injection and i am aware that the stock i/c spray kit is not as impressive however i personally would choose something other then water to cool my combustion temp. i've installed an alcohol spray kit into an 95 3000gt vr4 and it worked great just because the car from factory had a fuel cut off when certain amount of boost is reached, that kit actually cooled the temp also kept the car from cutting off when excessive boost is reached, it is a system thats monitored very carefully too, the point is, if system fails with the aquamist you risk hydrolocking your motor, the system fails with alcohol you'll run your engine too rich, you'll probably notice it before anything major could happend, andyou'll probably pick that up from your a/f ratio monitor. which i thnk is a must for turbo cars along with an egt. its just my opinion thats all...
Billy
