1 - 6 of 6 Posts
*GROUP BUY - 30% OFF - ONE WEEK ONLY*
GROUP BUY DETAILS:
The terms are very simple:
  • For the price listed below, you will get you one EBCS w/ wiring harness, three fittings and 4 feet of vacuum line (This keeps the price down for you and you guys are all smart, you can come up with a cheap alternate mounting method!)
  • GB runs from right now through 11:59pm on Friday 1/30
  • Minimum number or participants = 5
  • Maximum number of participants = 15
  • Place you order by sending us a PM. Once we have 5 people on the list we will take payment and ship product. If we don't reach 5 people nothing happens, if we hit 15 people the GB is over.
$75 SHIPPED
1. cjs06 - IWSTI
2. Vires - Local
3. Moody - Local
4. joesubierex - NASIOC
5. daddyphatsax304 - NASIOC
6. Satterthwaite - Local
7.
8.
9.
10.
11.
12.
13.
15.
PRODUCT DESCRIPTION:
The ASI 3-Port Electronic Boost Control Solenoid (EBCS) is the most robust and fastest acting MAC Valve based boost controller on the market. Users can expect faster boost response and solid boost control and tuners can expect more consistent results compared to the OEM solenoid or any other aftermarket 3-Port controller. Each kit comes complete with a plug and play connector, high quality nickel plated high flow fittings, quality silicone vacuum line.
Rather than order an off the shelf valve, which is very cheap for us to do and put a sticker on it, we worked closely with engineers at MAC to design and build our valves with a few custom options to improve the look and performance of our product.
  • We start by using a higher power coil in the valve that reacts faster than the standard coils offered in all the other MAC valves while still maintaining compatibility with the OEM ECU. The faster reacting coil was tested in a back to back comparison to similar products resulting in a lower wastegate duty cycle (WGDC) for a given boost target, meaning our valve does not have to work as hard to maintain boost levels reducing wear and tear on the valve.
  • We did not stop there, not only does our valve react faster to inputs, but we use a coil designed for higher operating temperatures. This allows the valve to operate flawlessly even under extreme heat condition found in an engine bay.
  • Our valves are then assembled with high temperature grease and viton seals so that it can withstand the harsh conditions under your hood.
  • Finally our valves are coated black to allow for a stealth install.
All of these modifications create the most dependable solenoid available and allows us to offer the only lifetime warranty for any MAC based EBCS on the market.
FEATURES:
  • Fastest Acting Best Flowing Valve on the Market
  • OEM Weatherproof Wiring Harness Connector
  • High Flow Nickel Plated Fittings and Silicone Vacuum Line
  • High Temperature Coil and Grease for Long Service Life
  • Viton Seals
  • Stealth Black Finish
  • Lifetime Warranty
IN STOCK READY TO SHIP - HELP US MAKE SOME ROOM TO BRING YOU GUYS SOME NEW PRODUCTS!
Discussion Starter #6 (Edited)
Well we didn't get to 10 for the additional discount but invoices are going out today. If you are on the list you should have a PM from us asking for your information.
If for some reason you missed this last week, I will accept any emails or PMs through the end of the day and will be closing the thread by the end of the day. If the thread says closed then the GB is officially over!
1 - 6 of 6 Posts
