Hello everyone. After having been without my 2005 STi for 10 months (spun rod bearing, no cash to fix) I finally finished my mechanical engineering degree, and will soon have a well enough paying job to where I can beginning taking the steps to rebuild the engine with a forged bottom end, and some other goodies. Naturally I am looking into a turbo upgrade.
At first I was set on a rotated Borg Warner, and I still might go this route. However my tuner has strongly pushed me toward a bolt-on Blouch turbo as he has much more experience with this set-up. He would like to stick to a 73mm MAF, and not go to speed density without a stand-alone ECU which is out of the budget at the moment. The Blouch Dominator 3.0 seems to be a good choice to hit the magic 400whp mark, and it seems the Dominator 3.5 is a good improvement on an already good thing. I am not stuck on the numbers per say, but I would like to be able to get into the low 11's at Bandimere which is about 5800 ft. ASL.
Before my engine had the bearing failure I was stage 2 with an EWG and an upgraded fuel system. Currently my mods are:
Cobb Gen. 2 Accessport Stage 2
Invidia V3 downpipe (Ti heat wrapped)
Cobb Catback custom modded with a 3" flange, Grimm Speed Gaskets
Kartboy Exhaust Hangers
Kartboy Pulley
Grimmspeed EWG Up-pipe (Ceramic Coated/Ti Heat Wrapped)
Grimmspeed Hybrid EBCS/MBC
Grimmspeed WG Bracket
PTP Turbo Blanket
Walbro 255 lph
DW 850cc Injectors
Tial MV-S 38mm EWG
I am planning on adding a wideband O2 sensor, some sort of upgraded intercooler, and a meth injection kit (OT: open to suggestions on which of these is recommended).
Does anyone have any first hand experience with the DOM 3.5? I am specifically looking at the 3 in. inlet with the 10 cm^2 hotside. I have done a lot of searching and found a whole lot of nothing.
Thanks for the replies.
Kartboy Pulley
PTP Turbo Blanket
Walbro 255 lph
DW 850cc Injectors
Tial MV-S 38mm EWG
