1 - 17 of 17 Posts
I've had 2 Blackstone reports done on my oil and I have questions that Blackstone can't really seem to answer fully. Look at the report and look at the lead content.
On the first report it's at 126 ppm, which is sky high according to universal averages. They asked if I ran leaded fuel or used a lead additive (obviously not). I called them and they basically said it was an anomaly since it was the only element that was out of whack. Fast forward to today. The lead content is still at 51 ppm (universal average is 7 ppm). What am I seeing here? They told me if it was a bearing failure in progress I would see other elements that were high also, yet they are all low or even below average.
Any insight? Am I worrying over nothing?
WolfPlayer said:
As a side note, you had 7500 miles on the oil with the higher lead content. IMHO, for a car that *might* be seeing some heavy WOT, that is too much. The lead also dropped in your next report because you had less miles on it.
t
True. Since then I have decided to start changing out at 3,750. So, this number is nothing to worry about yet? The reason I am concerned is it's so far above the typical mark and they bring attention to it in the notes, but they seem to not really have an idea why it's like that except that they think I'm running leaded gas.
· Premium Member
IMHO, seeing high lead values is an issue unless you can attribute it to something else (like leaded gas, additives, bad test, contamination, etc). The sucky part of oil reports is that when you see the high numbers for stuff like lead, tin, aluminum, and iron then usually there is nothing you can do at that point except worry. If your car is eating a bearing the report might show that but what are you going to do? Pull the motor and take it apart so you can find out for sure? Nope. Maybe if it was a race car OR if you had a lot of money to spend.
Oil reports are nice. But they suck too :(
t
· Premium Member
Bearing failure almost always shows lead and other metals with it. Since no other values are out of bounds its hard to say if it is really a bearing failing. I know I would be worried even with the 51 ppm figure being so high compared to the reference level. There are only so many areas in the motor that lead comes from and its probably safe to assume that is not from the composition of the oil itself.
Discussion Starter · #6 ·
I guess there's nothing I can do, but drive it. I do hate having the knowledge like WolfPlayer said and not really being able to do anything about it. I'll still get my reports done just to keep an eye on it and maybe it will help me anticipate or expect a problem/failure so I'm not completely surprised.
Sounds scumbag-ish, but you could trade out of it : (
Lead comes from bearings, where else? Could your bearings be wearing extremely rapidly? Mobil1 is usually pretty thin, meaning it generally penetrates bearings better than most oils. It doesn't add up.
I know other Mobile1 UOA's are much better, but I'd still switch oils just to see what changes. You might consider letting your dealership know in advance that you anticipate a warranty repair and have documentation showing a forthcoming bearing failure. This should be a warranty repair.
You might consider getting Terry Dyson's opinion.
Edit: I referred this thread to a friend who knows this stuff, and he said:
mobil1's HTHS number isn't very high
it could be shearing out of grade in the bearing
If he's right, you might trying mixing a quart of Redline oil in. "Get the Dyson analysis!" he added.
This thread has been added to my list of STI UOA's:
http://www.iwsti.com/forums/showthread.php?t=61207
Discussion Starter · #9 ·
Edit: a friend says:
If he's right, you might trying mixing a quart of Redline oil in. Get the Dyson analysis!
Today I've been rolling it through my mind to try a different oil just to see if there is a difference. I'm going to let this oil change ride as is and send it away at my 36,000 service. Then, I'll switch over to something else (Amsoil or Royal Purple perhaps) and see what kind of results I get on the following report.
I didn't realize they had an extra special expert on staff. Maybe on this next submission, I'll pay a little more and let him look at it.
· IWSTI Club Level 11ty
Any updates on your lead situation?
I just got my report back from Blackstone (first one for me) at 26,000 miles using M1 5W 30. Mine was high (14), but not as high as yours. I don't have much to add to help you I just want to see if you had an update.
Discussion Starter · #11 ·
I quit using Blackstone because they wouldn't give me any suggestions or couldn't figure it out ("Are you using leaded gas?") Come on. I started sending mine in to Terry Dyson at www.dysonanalysis.com and he told me I have some accelerated bearing wear and gave me some suggestions. I'm trying those out and I'm going to send another sample in shortly.
Blackstone can do a Dyson test - the list is in the kit as well as on the website:
"Terry Dyson has more than 25 years of independent oil analysis interpretation and consultation work. At various points in his life, Terry has expanded his knowledge of oil and its properties by owning a fleet maintenance shop, participating in the ProSportsCar/IMSA Professional Road Racing Series across the United States, and serving as a hazardous waste and petroleum/lubricants officer for the US Army and Navy.
The Dyson Analysis package costs $60 and includes Blackstone's Standard Analysis and a TBN, with Terry's interpretation of the results. If you'd like a Dyson Analysis, please make a note of it on the slip when you send in the sample."
From looking at the dysonanalysis site it costs $50 for their test kit which includes everything in the Backstone tests. So why pay an extra $10 to have them do the tests and then pass the results on to Dyson for analysis when you could just have Dyson do both? Just wondering...I may be missing something though.
1 - 17 of 17 Posts
