1 - 20 of 3114 Posts
pwn n00bs
STi Table of Contents:
New front end - post #27
New wheels - 57Motorsport installed - post #35
#4 cylinder low compression - post #75
aspec shift knob - post #96
engine pulled - post #97
engine failure - post #106
build list - post #144
long block pics - post #177
motor is in - post #221
wiring carnage - post #271
new motor on the dyno - post #377
pickup at EFI! - post #387
interior tear down - post #437
defi relocation - post #440
trip to EFI logics/overheating issue - post #590
first oil change/drain plug - post #625
PROVA steering wheel - post #639
very clean pictures - post #665
EFI Logics first tune pictures - post #734
new duramax/DD - post #782
dyno run 510/473 - post #863
full blown dual walbro pics - post #868
rally armor mud flaps - post #925
crawford gymkhana exhaust pics + video - post #981
invidia n1 race w/ti tip - post #1027
clean pics - post #1045
enkei pf01's powdercoated red mounted - post #1123
MORE enkei pictures - post #1141
few exterior changes - post #1252
syms sides and dress up bolts - post #1422
few pics - post #1505
EFI Logics Mega Meat 10/1/11 - post #1608
10/13/11 - T3h_Clap's Wheel33list Blog Feature
bent kw3's - post #1799
repainted intercooler core (eastwood rad paint) - post #1930
AST 4100's with Swift springs (8k/7k) - post #2060
wheel fell off/damage pictures - post #2114
engine bay dress up - neon yellow!! - post #2202
EFI Logics Mega Meet 5/19/12 - post #2237
Black PF01s installed w/Prova Yellow Mirrors - post #2774
2005 Subaru WRX STi
93 Octane + Meth Injection + Speed Density
Engine:
  • COBB Accessport V3
  • AEM Meth Injection
  • Spec C Tank w/Meth
  • STi GR Nitride Crank
  • Manley H Beam Plus Rods
  • Supertech 100mm Pistons
  • Supertech +1mm Intake and +1mm Exhaust Valves
  • Supertech Titanium Retainers
  • Supertech Valve Springs
  • Cosworth S2 Grind Camshafts 278/274
  • ACL Race Rod/Main Bearings
  • ARP Head Studs
  • Invidia N1 Race w/Ti Tip Catback
  • Ultimate Racing GTX3582R 1.06 A/R Turbo
  • Ultimate Racing Downpipe
  • Ultimate Racing 3 Bolt Uppipe
  • Ultimate Racing Reverse Flow Ver1 FMIC
  • Tomei Equal Length Header
  • Perrin Performance A/O Separator
  • KS Tech 83mm MAF Housing
  • Full Blown Dual Walbro 255 Pump Setup w/Custom Lines
  • Blitz SBC ID3 Boost Controller
  • TIAL MV-R External Wastegate
  • TIAL BOV
  • Aeromotive Fuel Rails
  • Aeromotive Fuel Pressure Regulator with Liquid-Filled CHM Gauge
  • Radium Engineering Pulse Damper
  • Injector Dynamics 1300cc Injectors
  • KOYO Race Aluminum Radiator
  • KillerB Motorsport Oil Pan + Pickup Tube
  • KillerB Oil Fill Tube
  • Zerolift Composite TGV Deletes
  • NGK One Step Colder Plugs
  • Fluidamper Crank Pulley
  • 11mm GR Oil Pump
  • Prova Radiator Cap
  • Prova Oil Cap
  • XS Power S680 Battery
  • Samco Sport Radiator Hoses
  • Coolant Reservoir Deleted
  • Gates Racing Timing Belt
  • Carbign Craft Carbon Fiber Alternator Cover
  • Carbign Craft Carbon Fiber Radiator Shroud
  • Dress Up Bolts Polished Engine Bay Bolts
  • Project MU Brake & Clutch Caps (not made anymore, extremely rare!)
  • NRG Carbon Fiber Hood Dampers
  • AEM 3.5 MAP Sensor
Exterior:
  • Genuine Cusco Front Lip
  • Chargespeed Genuine Carbon Fiber Bottomline Side Skirts
  • Chargespeed Genuine Carbon Fiber Vortex Generator
  • Voltex Carbon Fiber Rear Diffuser
  • Voltex Wing Delete
  • Prova Yellow Wide Angle Mirrors
  • S2000 Retrofit Headlights w/Angel Eyes/Blacked Out
  • 10% Window Tint
  • Debadged
  • Blue Bat's Tinted Tails + 3rd Brake Light
  • Pillarless Grille Mod Painted OBP
  • Black STi Billet Aluminum Front Bumper Trim
  • Varis Carbon Fiber Exhaust Shield
  • Varis Carbon Fiber B-Pillars
  • Hella's
Interior:
  • Recaro Leather Speed Seats (Custom Ordered)
  • WRX Black Carpet/Door Cards/Rear Seat w/Pass Through
  • PROVA D-Shaped Steering Wheel
  • Aspec Shift Knob
  • S204 Style Flat Black Dash Trim
  • AEM AFR Gauge
  • Autometer Carbon Fiber Gauge Pods
  • DEFI BF Amber Boost
  • DEFI BF Amber Oil Pressure
  • DEFI BF Amber EGT
  • DEFI Control Unit II
  • DEFI Triple Meter Hood
  • Fully Converted Interior Lights to Red
  • Subtle Solutions Ashtray Bezel
  • Auto-Dimming Mirror/Compass
  • Polished STi Shifter Surround
  • JDM Carbon Shift Pattern Decal
  • Autospeed Dead Pedal
  • Passport 8500 X50
  • Forester DIN Pocket
  • Alpine iDA-X305 Digital Media Receiver
  • Alpine Type-R Speakers
Drivetrain:
  • Enkei PF01 Black 18x9 +45
  • Conti Extreme Contact 255/35/18
  • Project KICS R40 Neochrome Lug Nuts
  • Kartboy Short Shifter W/All Bushings
  • Kartboy Crossmember and Transmission Bushings
  • ACPT Carbon Fiber Driveshaft
  • South Bend Stage 3 Daily Clutch
  • Competition Clutch Lightweight Flywheel
  • Goodridge SS Clutch Line
  • Torque Solution Motor/Tranny Mounts
  • JLM Motorsports Pitch Stop Mount
Suspension & Stiffening:
  • AST 4100 Coilovers w/Swift Springs & Helpers (8k/7k)
  • RCE Lowering Front Adjustable Camber Plates (not made anymore, extremely rare!)
  • Vorshlag Rear Adjustable Camber Plates
  • The Car Labs X-Brace
  • Whiteline 24mm Adjustable Front/Rear Sway Bars
  • Kartboy Rear Endlinks
  • Kartboy Front Endlinks
  • Whiteline Subframe Locking Bolts
  • Whiteline Sport ALK Kit
  • Whiteline Adjustable Lateral Links
  • Cusco Adjustable Trailing Arms
  • Offensive Power Front Fender Braces
  • JDM Titanium Front Strut Bar
  • GT Spec 3-Piece Subframe
Brakes:
  • Gloss Black Powdercoated Brembo's
  • DBA 5000 Front Drilled/Slotted Roters
  • DBA 4000 Rear Slotted Rotors
  • Hawk HPS + Front/Rear Pads
  • Cusco Master Cylinder Brace
  • Goodridge SS Lines
  • Motul RBF600 Fluid
Re: Billy's GT35R'd OBP 05 STi - it's here!
i wouldnt use the term muscle, but its def something that demands respect.
ummm this car was featured in a mag and the head line was "modern muscle" so yea... i did use the term muscle.
Good luck with the car, I hope to see it run 10's because this car is flat out fast, even faster probably then when Al had it.
Congrats.
-Jordon
Damn you Billy you now have a very well known car.. al set this car up great and Cicio to. hope you make this badboy run right.
pwn n00bs
Discussion Starter #10
agreed. i would never go for a used STi, but this one is great.
everything is setup great, but of course i will change things to accustom the car to me.:)
Administrator
pwn n00bs
Discussion Starter #13
the plans are going come as i go really. i have to get acquainted with the car first before i start changing it all.
Congrats! THis car is stupid fast, i had a chance to ride in it right after Doug tuned it. It was on race gas and 30psi and i couldn't even reach out of the seat, it was scary in an awesome way, I'm sad to see it leave ND, but it will be put to better use where there are some tracks for this monster.
Nice, I cant wait to see this car. Im also on my way to a 35r :devil:.
I Solve Problems
looking good.
needs some wider wheels. :)
