1 - 10 of 10 Posts
i just installed a bigger tmic and its rubbing on something and i can't tell wat its rubbing on its really annoying when ur in the car can someone help me out?
it sounds like its coming from under the ic cause when i push down on it it makes the sound i hear from inside the car.
I had the same problem when I put in my Spearco. I solved the problem by putting in a catchcan which let me get rid of the hard pipe that bolts to the IC. Has to be done if you go front mount as well.
Check the AC line behind the intercooler. I had to deal with a rattle from the AC line with stock IC.
that could be it too. sometimes you have to moce the part of the a/c line on the driver side behind the tmic down a bit. i think its pretty easy to relocate. you dont need to add anything, just move the bracket down a hole or something like that.
o ok im going to go take a look at it real quick
Discussion Starter · #8 ·
so i just looked at it i think it mite be these little plastic clips that hold the water sprayer hose to the hood thats making the noice
My spearco rubbed against the hood. The noise went away after it made (wore) it's own custom "mark". I also removed the plastic clips and re-routed the hose through the hood and out the washer nozzle.
Discussion Starter · #10 ·
o ok i mite do thats thanks for ur help guys.
1 - 10 of 10 Posts
